Results 1 to 5 of 5
Thread: Audio EffectMultiply doesn't work
    Oct 2017
    Ukraine
    33
    Hello! I am using T3.2
    Audio EffectMultiply doesn't work for me, here's an example:
    AudioInputAnalog         adc2(A3);           //xy=122,205
    AudioInputAnalog         adc1(A4);           //xy=123,113
    AudioEffectMultiply      multiply1;      //xy=478,157
    AudioOutputAnalog        dac1;           //xy=730,150
    AudioConnection          patchCord1(adc2, 1, multiply1, 1);
    AudioConnection          patchCord2(adc1, 0, multiply1, 0);
    AudioConnection          patchCord3(multiply1, dac1);
       AudioMemory(20);
    1,080
    Try this which inputs from channel 0 of adc2:
    AudioConnection          patchCord1(adc2, 0, multiply1, 1);
    Pete
    Oct 2017
    Ukraine
    33
    I tried to replace, does not work.
    I have 2 signals at the inputs, 120 Hz (yellow line) and 100 Hz, after multiplying these should be approximately like this (blue line)
    and there is so
    Oct 2017
    Ukraine
    33
    Hello! I checked the internal signals. If the input of the AudioEffectMultiply multiply1 is to give 2 inward sine AudioSynthWaveformSine sine1 and sine2 then the multiply1 works.
    I repeat - multiply does not work with external ADC1 and ADC2 signals.
    Oct 2017
    Ukraine
    33
    Hello! I checked AudioInputAnalogStereo adcs1 (A5, A3); AudioInputAnalogStereo adcs1 (A5, A3) works; together with AudioEffectMultiply multiply1;
    If the ADC channels are defined separately
    AudioInputAnalog adc2 (A5); // xy = 122,205
    AudioInputAnalog adc1 (A3); // xy = 123,113
    then AudioEffectMultiply multiply1; does not work.
