So I am going to be putting a 10k pot wheel onto the audio board gnd,vol,3.3v pins and want to make it so that when the wheel is turned, it will increase or decrease the volume. I know to get the value of the wheel it should be int val = analogRead(A1); but then I'm not sure how to use that and the changes in that to change the volume up and down.
Here is my full code so far:
AudioPlaySdWav playSdWav1;
AudioOutputI2S i2s1;
AudioConnection patchCord1(playSdWav1, 0, i2s1, 0);
AudioConnection patchCord2(playSdWav1, 1, i2s1, 1);
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 14
//#define SDCARD_CS_PIN BUILTIN_SDCARD
//#define SDCARD_MOSI_PIN 11 // not actually used
//#define SDCARD_SCK_PIN 13 // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN 4
AudioMemory(8);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1) {
int val;
if (playSdWav1.isPlaying() == false) {
Serial.println("Start playing");
playSdWav1.play("AoaPP.WAV");
delay(10); // wait for library to parse WAV info
Serial.print("analog 0 is: ");
Serial.println(val);
//TODO: Change volume based on analog
