Page 27 of 27 FirstFirst ... 17 25 26 27
Results 651 to 667 of 667
Thread: FlexCAN_T4 - FlexCAN for Teensy 4
  1. #651
    Dec 2016
    Montreal, Canada
    3,698
    thats a different id and doesnt correlate to your sends, is the device sending you that? what is the device?
  2. #652
    Apr 2021
    19
    Power Supply Huawei R4850
  3. #653
    Dec 2016
    Montreal, Canada
    3,698
    well you need the manual for it then, i tried googling and came up with this:
    https://github.com/craigpeacock/Huaw.../Protocol.xlsx
    the IDs dont match what your sending or receiving, but since your receiving something it means your sending the wrong/right data to the wrong canid thats why it's not responding
  4. #654
    Apr 2021
    19
    yes, this is the document I use,
    but it turns out that nothing works, I am sure that I am doing something wrong,
    but I can't understand what am I doing wrong? if the error is in the team, how should it be correct?
    maybe I'm not forming the team correctly ?
  5. #655
    Apr 2021
    19
    wow .... found a bug !!!
    I had it like that:
    msg.buf[0] = 0x01;
    msg.buf[1] = 0x01;
    did so:
    msg.buf[0] = 0x01;
    msg.buf[1] = 0x00;
    now the voltage switches very quickly,
    but another problem appeared, this voltage changes for 1 minute,
    then reverts to the previous value!
    now you need to figure out how to remember it ?
    it looks like now I need to send two commands in a row,
    switch and remember, do I understand correctly ?
  6. #656
    Dec 2016
    Montreal, Canada
    3,698
    did you read last line of the xlsx?
    The rectifier can operate in two states:
    Off-line is when there is no CAN communication (i.e. standalone operation). This occurs on power-up or if CAN communication has timed-out (Orange LED slowly blinking).
    On-line values are only valid when CAN communication is present (Orange LED not blinking). These values are volatile and reset to default on loss of CAN comms.
    CAN communication time-out is approximately 60 seconds. i.e. if you stop sending valid CAN messages to the rectifier, the rectifier will switch to Off-line/Default values in approximately 60 seconds.
    You basically need to keep transmitting whatever within 60 seconds for it to remain active, if you stop transmitting for 60 seconds thats it. so send every 30 seconds if you want
  7. #657
    Apr 2021
    19
    yes, now thanks to you, I understood everything
    I am very grateful to you for your help!
    and if, can you tell me how to write the code correctly, for these purposes ?
    I will be your debtor!
  8. #658
    Dec 2016
    Montreal, Canada
    3,698
    1 then 0 workes because on the chart, Online in green is for CAN, because you were sending 1 then 1, you actually disabled canbus so the normal voltage would be output, Offline meant no canbus traffic allowed
  9. #659
    Dec 2016
    Montreal, Canada
    3,698
    try using the FIFO with interrupts example so you can see what the responses are, then try to send the message with byte0 as 1 and byte 1 as 0 and repeat send in loop with delay(5), see what it responds?
    everytime its sending every 5 seconds, the powersupply 60 second counter resets, so it shouldnt timeout since your hitting it every 5 seconds, thats more of a powersupply safety, if no data is communicating it'll most likely shut down and wait
  10. #660
    Apr 2021
    19
    Thank you for your reply!
    but for me it is difficult, I cannot do that, I lack knowledge
    I plan to send two commands sequentially,
    first online, then offline, probably this is not correct, but otherwise I have no idea how to do it
  11. #661
    Dec 2016
    Montreal, Canada
    3,698
    this?
    #include <IFCT.h>
    CAN_message_t msg;
      Can0.setBaudRate(125000);
      Can0.enableFIFO();
      msg.ext = 1;
      msg.id = 0x108180fe;
      msg.len = 8;
      msg.buf[0] = 0x01;
      msg.buf[1] = 0x00;
      msg.buf[2] = 0x00;
      msg.buf[3] = 0x00;
      msg.buf[4] = 0x00;
      msg.buf[5] = 0x00;
      msg.buf[6] = 0xd6; //Voltage
      msg.buf[7] = 0x00;
      Can0.write(msg);
    Can0.write(msg);
    delay(5000);
  12. #662
    Apr 2021
    19
    this?
    #include <IFCT.h>
    CAN_message_t msg;
      Can0.enableFIFO();
      msg.ext = 1;
      msg.len = 8;
      msg.buf[0] = 0x01;
      msg.buf[1] = 0x00;
      msg.buf[2] = 0x00;
      msg.buf[3] = 0x00;
      msg.buf[4] = 0x00;
      msg.buf[5] = 0x00;
      msg.buf[7] = 0x00;
      Can0.write(msg);
    Can0.write(msg);
    delay(5000);
    Yes fine! Thank you!
  13. #663
    Apr 2021
    19
    tonton81, maybe you will have a free minute,
    can you show me how to receive data from a block please?
    with not a lot of sample code?
  14. #664
    Dec 2016
    Montreal, Canada
    3,698
    you need to use the "FIFO with interrupts" example and use the same loop() with delay you added earlier, then you'll see the responses every 5 seconds you transmit, according to the xlsx, you'll get a frame reply ACK after the send
  15. #665
    Apr 2021
    19
    ok, I understand you, I will try to figure it out.
    thank you again for your time!
  16. #666
    Great work here. I am try to find out more of an understanding of the best way to set up for receiving specific messages. But, I do not know the messages at compile time so I need to set the filters in a loop. I am reading in a DBC file and I only want to receive messages in the DBC file.
    Is this possible?
    Also, what happens if I need to receive more than 128 messages? Can you set filter masking?
    Is is 128 filters per channels or for all 3 channels?
    Thoughts on the best way to set up MB/FIFO (either/or/both) when you do not know what the messages are in advance of compile time?
    Any hints where to find more information on filtering/masking?
    Bruce
  17. #667
    Dec 2016
    Montreal, Canada
    3,698
    I don't see a need to filter excessively each id. FIFO has 128 filters however only the first 32 are independant, the rest work off a global filter that doesn't sense to use. There are also 64 mailboxes on T4 and 16 on T3. each mailbox (or channel as you call it?) is ONE filter, but the functions allow mixing one or more IDs on ONE filter. You can use mailboxes, or FIFO, or both. Most people use FIFO for ordered receptions and you can use additional mailboxes for interrupt (or if not using interrupts the mailboxes guarentee the latest stored ID frame remains in that mailbox until read, so other frames won't jump in, good for polling). Most people will just use FIFO with interrupts, no need for mailboxes, you can apply filters to FIFO via setFIFOFilter(0, 0x123, STD);
    FILTER #0, CANID 0x123, STANDARD FRAME
    by default, FIFO consumes 8 mailboxes leaving the rest as transmit, and 8 filters (0-7).
    Teensy is fast enough to not drop frames, you can just filter your ID in the callback:
    if ( msg.id == 0x123 ) { doSomething(); }
