Tried out the Waveshare board: it works! Does exactly what I'd hoped.
Will try the previous transceiver board one more time just for fun (I think I may have plugged in CanH/L to a couple of analog inputs instead of the Can ports in my haste this morning).
#include <FlexCAN_T4.h>
// CAN bus defines
#define VCAN_SILENT_PIN 2
#define VCAN_TERMINATOR_PIN 8
#define LCAN_SILENT_PIN 20
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> LCAN;
FlexCAN_T4<CAN2, RX_SIZE_256, TX_SIZE_16> VCAN;
pinMode(LCAN_SILENT_PIN, OUTPUT);
pinMode(VCAN_SILENT_PIN, OUTPUT);
pinMode(VCAN_TERMINATOR_PIN, OUTPUT);
digitalWrite(LCAN_SILENT_PIN, LOW); /* optional transceiver silent pin: HIGH = Silent */
digitalWrite(VCAN_SILENT_PIN, LOW); /* optional transceiver silent pin: HIGH = Silent */
digitalWrite(VCAN_TERMINATOR_PIN, HIGH); /* optional bus terminator enable pin*/
Serial.begin(500000);
// Setup VCAN
VCAN.begin();
VCAN.setBaudRate(500000);
VCAN.enableFIFO();
VCAN.enableFIFOInterrupt();
VCAN.onReceive(canWrite);
// Setup LCAN
LCAN.begin();
LCAN.setBaudRate(500000);
LCAN.mailboxStatus();
VCAN.events();
LCAN.events();
void canWrite(const CAN_message_t &msg) {
CAN_message_t myMsg;
myMsg = msg;
myMsg.seq = 1;
LCAN.write(myMsg);
void ext_output1(const CAN_message_t &msg) {
myMsg = msg;
myMsg.seq = 1;
LCAN.write(myMsg);
Have you tried setting setClock to 60MHz? Thats what I am using in my vehicle at 500kbps
The background handler works because it is direct, no filter, to all receptions, without using the queue. Perhaps the bus is filling the queue too fast? You can check the RX queue size during runtime by printing next 12 bits of events(). 0xFFF000 masked >> 12 will return the value of frames in the queue. If you prefer not using the queue, the external callback will work, but there will be no software filter for canids in that function
For bridging it is good to have direct callback response system like your using via external callback, queues in bridge mode is kinda useless as it will follow the delays of the loop for each events() cycle. If your filtering specific frames or doing normal CAN, using it normally is fine
Sequential frames require events() to be triggered as well. So keep that spinning or try without sequential bit if ordering is not important, you could fill all the TX mailboxes that way
#include <FlexCAN_T4.h>. // [COLOR="#FF0000"]last available version[/COLOR]
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> Can0;
void setup(void) {
while (!Serial) ;
Can0.begin();
Can0.setBaudRate(500000);
Can0.setMaxMB(16);
Can0.setClock(CLK_60MHz); // [COLOR="#FF0000"]with or without is the same[/COLOR]
Can0.distribute(); // [COLOR="#FF0000"]change a bit but nothing[/COLOR]
/* MB filters * // [COLOR="#FF0000"]MB filters version[/COLOR]
Can0.enableMBInterrupts();
Can0.onReceive(canSniff);
Can0.setMBFilter(REJECT_ALL);
Can0.setMBFilter(0, 0x100); // transmitted every 10ms (Speed)
Can0.setMBFilter(1, 0x101); // transmitted every 20ms (RPM)
Can0.setMBFilter(2, 0x102); // transmitted every 20ms (Throttle pos)
Can0.setMBFilter(3, 0x103); // transmitted every 100ms (ECT)
Can0.setMBFilter(4, 0x104); // transmitted every 20ms (Gear)
/* FIFO filters */ // [COLOR="#FF0000"]FIFO filters version[/COLOR]
Can0.enableFIFO();
Can0.enableFIFOInterrupt();
Can0.onReceive(FIFO, canSniff);
Can0.setFIFOFilter(REJECT_ALL);
Can0.setFIFOFilter(0, 0x100, STD);
Can0.setFIFOFilter(1, 0x101, STD);
Can0.setFIFOFilter(2, 0x102, STD);
Can0.setFIFOFilter(3, 0x103, STD);
Can0.setFIFOFilter(4, 0x104, STD);
Can0.mailboxStatus();
void canSniff(const CAN_message_t &msg)
Serial.print("MB "); Serial.print(msg.mb);
Serial.print(" OVERRUN: "); Serial.print(msg.flags.overrun);
Serial.print(" LEN: "); Serial.print(msg.len);
Serial.print(" EXT: "); Serial.print(msg.flags.extended);
Serial.print(" TS: "); Serial.print(millis());
Serial.print(" ID: "); Serial.print(msg.id, HEX);
Serial.print(" Buffer: ");
for ( uint8_t i = 0; i < msg.len; i++ ) {
Serial.print(msg.buf[i], HEX); Serial.print(" ");
} Serial.println();
Can0.events();
delay(20); // [COLOR="#FF0000"]this simulates the time to show data on screen (BT816 GPU)[/COLOR]
Can you copy your callback but rename the new one to
"ext_output1"
And disable events() in loop
Let me know results
FlexCAN_T4<CAN3, RX_SIZE_256, TX_SIZE_16> Can0;
void setup(void) {
Serial.begin(115200); delay(400);
pinMode(6, OUTPUT); digitalWrite(6, LOW); /* optional tranceiver enable pin */
Can0.begin();
Can0.setBaudRate(1000000);
Can0.setMaxMB(16);
Can0.enableFIFO();
void canSniff(const CAN_message_t &msg) {
Serial.print(" TS: "); Serial.print(msg.timestamp);
} Serial.println();
static uint32_t _time = millis();
Serial.print("Time between frames: ");
Serial.println(millis() - _time);
_time = millis();
Can0.events();
static uint32_t timeout = millis();
if ( millis() - timeout > 200 ) { [COLOR="#FF0000"][B]// change the sender time here[/B][/COLOR]
CAN_message_t msg;
msg.id = random(0x1,0x7FE);
for ( uint8_t i = 0; i < 8; i++ ) msg.buf[i] = i + 1;
Can0.write(msg);
timeout = millis();
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 63101 ID: 49A Buffer: 1 2 3 4 5 6 7 8
Time between frames: 201
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 2210 ID: 412 Buffer: 1 2 3 4 5 6 7 8
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 6050 ID: 25D Buffer: 1 2 3 4 5 6 7 8
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 10315 ID: 245 Buffer: 1 2 3 4 5 6 7 8
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 14691 ID: 2E8 Buffer: 1 2 3 4 5 6 7 8
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 19245 ID: 73A Buffer: 1 2 3 4 5 6 7 8
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 23626 ID: 745 Buffer: 1 2 3 4 5 6 7 8
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 27618 ID: 5E7 Buffer: 1 2 3 4 5 6 7 8
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 31936 ID: 733 Buffer: 1 2 3 4 5 6 7 8
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 36123 ID: 3D7 Buffer: 1 2 3 4 5 6 7 8
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 40516 ID: 332 Buffer: 1 2 3 4 5 6 7 8
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 44752 ID: 17 Buffer: 1 2 3 4 5 6 7 8
void setup(void) {
Can0.begin();
Can0.setMaxMB(16);
Can0.enableFIFO();
} Serial.println();
_time = millis();
Can0.events();
if ( millis() - timeout > 2 ) {
static CAN_message_t msg;
msg.id++;
if ( msg.id > 0x7FE ) msg.id = 0x1;
static int16_t val = -1;
val++;
if ( val > 7 ) val = 0;
for ( uint8_t i = 0; i < 8; i++ ) msg.buf[i] = val;
Can0.write(msg);
timeout = millis();
Time between frames: 3
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 31483 ID: 708 Buffer: 5 5 5 5 5 5 5 5
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 34483 ID: 709 Buffer: 6 6 6 6 6 6 6 6
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 37483 ID: 70A Buffer: 7 7 7 7 7 7 7 7
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 40483 ID: 70B Buffer: 0 0 0 0 0 0 0 0
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 43482 ID: 70C Buffer: 1 1 1 1 1 1 1 1
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 46482 ID: 70D Buffer: 2 2 2 2 2 2 2 2
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 49482 ID: 70E Buffer: 3 3 3 3 3 3 3 3
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 52482 ID: 70F Buffer: 4 4 4 4 4 4 4 4
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 55482 ID: 710 Buffer: 5 5 5 5 5 5 5 5
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 58482 ID: 711 Buffer: 6 6 6 6 6 6 6 6
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 61482 ID: 712 Buffer: 7 7 7 7 7 7 7 7
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 64481 ID: 713 Buffer: 0 0 0 0 0 0 0 0
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 1945 ID: 714 Buffer: 1 1 1 1 1 1 1 1
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 4945 ID: 715 Buffer: 2 2 2 2 2 2 2 2
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 7945 ID: 716 Buffer: 3 3 3 3 3 3 3 3
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 10944 ID: 717 Buffer: 4 4 4 4 4 4 4 4
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 13944 ID: 718 Buffer: 5 5 5 5 5 5 5 5
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 16944 ID: 719 Buffer: 6 6 6 6 6 6 6 6
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 19944 ID: 71A Buffer: 7 7 7 7 7 7 7 7
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 22944 ID: 71B Buffer: 0 0 0 0 0 0 0 0
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 25944 ID: 71C Buffer: 1 1 1 1 1 1 1 1
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 28944 ID: 71D Buffer: 2 2 2 2 2 2 2 2
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 31943 ID: 71E Buffer: 3 3 3 3 3 3 3 3
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 34943 ID: 71F Buffer: 4 4 4 4 4 4 4 4
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 37943 ID: 720 Buffer: 5 5 5 5 5 5 5 5
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 40943 ID: 721 Buffer: 6 6 6 6 6 6 6 6
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 43943 ID: 722 Buffer: 7 7 7 7 7 7 7 7
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 46943 ID: 723 Buffer: 0 0 0 0 0 0 0 0
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 49943 ID: 724 Buffer: 1 1 1 1 1 1 1 1
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 52942 ID: 725 Buffer: 2 2 2 2 2 2 2 2
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 55942 ID: 726 Buffer: 3 3 3 3 3 3 3 3
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 58942 ID: 727 Buffer: 4 4 4 4 4 4 4 4
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 61942 ID: 728 Buffer: 5 5 5 5 5 5 5 5
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 64942 ID: 729 Buffer: 6 6 6 6 6 6 6 6
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 2406 ID: 72A Buffer: 7 7 7 7 7 7 7 7
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 5406 ID: 72B Buffer: 0 0 0 0 0 0 0 0
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 8405 ID: 72C Buffer: 1 1 1 1 1 1 1 1
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 11405 ID: 72D Buffer: 2 2 2 2 2 2 2 2
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 14405 ID: 72E Buffer: 3 3 3 3 3 3 3 3
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 17405 ID: 72F Buffer: 4 4 4 4 4 4 4 4
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 20405 ID: 730 Buffer: 5 5 5 5 5 5 5 5
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 23405 ID: 731 Buffer: 6 6 6 6 6 6 6 6
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 26405 ID: 732 Buffer: 7 7 7 7 7 7 7 7
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 29404 ID: 733 Buffer: 0 0 0 0 0 0 0 0
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 32404 ID: 734 Buffer: 1 1 1 1 1 1 1 1
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 35404 ID: 735 Buffer: 2 2 2 2 2 2 2 2
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 38404 ID: 736 Buffer: 3 3 3 3 3 3 3 3
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 41404 ID: 737 Buffer: 4 4 4 4 4 4 4 4
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 44404 ID: 738 Buffer: 5 5 5 5 5 5 5 5
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 47404 ID: 739 Buffer: 6 6 6 6 6 6 6 6
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 50403 ID: 73A Buffer: 7 7 7 7 7 7 7 7
MB 99 OVERRUN: 0 LEN: 8 EXT: 0 TS: 53403 ID: 73B Buffer: 0 0 0 0 0 0 0 0
