Page 33 of 35 FirstFirst ... 23 31 32 33 34 35 LastLast
Results 801 to 825 of 854
Thread: FlexCAN_T4 - FlexCAN for Teensy 4
  1. #801
    Dec 2016
    Montreal, Canada
    3,871
    yeah it's still open on github's issue tracker, a user requested it so i added it in
          CAN_error_t error; /* create a message struct to store the queue details, for data accesses */
          if ( Can1.error(error, 1) ) { // overload 1 means internally print everything in error event to serial monitor
            // Do Something...
            if ( error.ACK_ERR ) Serial.print("ACK error occured");
            if ( !strcmp(error.state, "Transmitting") ) Serial.println("TRANSMITTING!");
    I've added the commits for error reporting, try it out
    (me hot-plugging the esp32 and reconnecting)
    FlexCAN State: Receiving, FLT_CONF: Error Active
    FlexCAN State: Idle, FLT_CONF: Error Active
    FlexCAN State: Transmitting, FLT_CONF: Error Active
    FlexCAN State: Transmitting, ACK_ERR, FLT_CONF: Error Active
    FlexCAN State: Transmitting, ACK_ERR, TX_WRN: 96, FLT_CONF: Error Active
    FlexCAN State: Transmitting, ACK_ERR, TX_WRN: 104, FLT_CONF: Error Active
    FlexCAN State: Transmitting, ACK_ERR, TX_WRN: 128, FLT_CONF: Bus off
    FlexCAN State: Transmitting, TX_WRN: 127, FLT_CONF: Error Active
  2. #802
    Jun 2021
    12
    can you please give usage example for ext_output1()
    I use your sketch CAN2.0_example_FIFO_with_interrupts.ino and don't know how to do it right. Currently I have placed my code inside canSniff() which is probably not intended this way.
    I have something to show meanwhile (it works but i don't like it)
    https://gitlab.com/aIecxs/w211-ac-control
  3. #803
    Dec 2016
    Montreal, Canada
    3,871
    ext_output1() is a background callback same as canSniff, it's intended for other libraries to access CAN data (isotp) without needing to add more sketch code to forward objects
    putting your code in canSniff is correct way, if it gets too cluttered you could make sub function calls from the callback
    bit more complex, you could also do individual mailbox filtering if you want each mailbox to receive a specific ID in it's own canSniff callback
    KOMP_STELL should be volatile char
    timeout should be volatile unsigned long, not long
    variables that share both ISR (canSniff) and loop should be declared volatile, however,
    if you are using Can.events(), voltaile is not needed. If you comment out events(), they should be volatile since theyll be from interrupt context
  4. #804
    Jun 2021
    12
    Thanks for that hints, really appreciate it!
    Although I don't understand what Can.events() does I believe I should keep it in main. I added sub function and changed integer types as suggested, but when try to set volatile struct I get compiler warnings. If you know how to fix feel free to send me commit.
    Have another issue with memcpy. I don't know how to map msg.buf into bit fields. It works fine with full bytes (uint8_t) and I receive KOMP_STELL correctly that means byte order is okay. I can even map single byte in little endian and receive bits (bool) for each 8-bit series in right order too. But it starts to fail for odd-numbered bit field size and empty paddings. I read here that we should use bit-wise operators instead, so I think I can throw my last commit into garbage.
    Do you have any other template how to map msg.buf, for example bit-wise operator?
    here is some example output of canSniff() https://pastebin.com/p4QuFHsn
  5. #805
    Dec 2016
    Montreal, Canada
    3,871
    i use something simple
    msg.buf[1] & (1U << 3)
    this gives you the bool at bit position 3 (from the right, of course)
    1U basically checks if it matches if bit is set (unsigned), left shifted 3 times
  6. #806
    146
    So I am trying to figure out how to use the ISO-TP with the present frame work I have.
    I am using the MB filtering to minimize the # of message ID (or a single ID if<60 ID's) that I have to search through so a maximum 2 ID assigned to a specific MB.
    The ISO-TP config does not report MB nor does it report the bus to which call back is originated from.
    The other issue there is broadcasted data on the same bus as the OBD data so for example mode 9 which requires iso-TP.
    For ISO-TP "if ( msg.buf[0] <= 7 ) { /* single frame */ " but we have no idea what msg.buf[0] will be in the case of broad cast can data.
    So not quite sure how we can have this implementation when there is broadcast data.
    Please let me know you thoughts.
    Bruce
  7. #807
    Dec 2016
    Montreal, Canada
    3,871
    you can comment out and disable if you don't want to receive single frames that you can just handle in your normal callback, if length is less than 7. The bus is assigned in the constructor as well as the callback, so the callback you'd assume the correct bus, but in terms of mailboxes, if the frames come from multiple mailboxes, how can it tell you where it came from? that would need to store even more data and mailbox counts in a bigger payload, making even more complex code.
  8. #808
    146
    When I parse the DBC file I know what ID's have PIDS associated with them. If there is more than one ID with PIDS then those are assigned to another set of PIDS.
    The ID are assigned to mail boxes as normal with 2 at the most. When the ID is matched in memory it also has a flag stating is has PIDS. Those PIDS are stored in it. You can up to 8 ECU's associated with a bus so you could have up to 8 ID of which multiple PIDs may respond to information ID's like CAL ID.CVN/ECU name so you would need the ability to handle this anyways. If you have 8 ECU's you could have 4 to 8 MB's associated with those ID's but you could have 8 ECU names so you would need to be able each of those separately anyways.
    Bruce
  9. #809
    Dec 2016
    Montreal, Canada
    3,871
    if they have a different CANID, they are assembled in parallel as the frames come in, the data is just appended to the queue, why would you bind a certain mailbox to a payload? i guess you could take the last MB frame issued and use that as a source of the frames before hitting the callback..
  10. #810
    Mar 2016
    Portland, OR
    710
    What's random doing in this method?
    https://github.com/tonton81/FlexCAN_...AN_T4.tpp#L942
    FCTP_FUNC int FCTP_OPT::read(CAN_message_t &msg) {
      bool _random = random(0, 2);
      if ( ( !_random ) && ( FLEXCANb_MCR(_bus) & FLEXCAN_MCR_FEN ) &&
           !( FLEXCANb_IMASK1(_bus) & FLEXCAN_IMASK1_BUF5M ) &&
           ( FLEXCANb_IFLAG1(_bus) & FLEXCAN_IFLAG1_BUF5I ) ) return readFIFO(msg);
      return readMB(msg);
    I can see that it would only occasionally trigger return readFIFO(msg), but I don't understand why it's setup this way.
  11. #811
    Dec 2016
    Montreal, Canada
    3,871
    it's just to pick between either mailbox or fifo at random.
    if fifo isn't enabled it will just fall down to read mailboxes only.
    readMB wont do anything as the function returns if you have no reception, only tx mailboxes.
    you can either readFIFO or readMB, I decided to pick at random because if one is always receiving, lets say FIFO is always pulling for every check, the mailbox would probably not be read as often, especially with slow user code.
    Obviously these 3 methods are for polling only. If you have interrupts enabled, they simply would return as they don't read interrupt enabled mailboxes
  12. #812
    146
    Yes, I use it exclusively for my teensy 4.1 application.
  13. #813
    Mar 2016
    Portland, OR
    710
    How do we emit messages with an extended id? Do we just set the CAN_message_t id field or is there some setup that's needed first?
  14. #814
    Dec 2016
    Montreal, Canada
    3,871
    msg.flags.extended = 1:
  15. #815
    Sep 2021
    14
    Can not receive CAN-Bus Frames with Teensy in conjunction with Waveshare SN65HVD230 C
    Hi guys,
    I have some basic beginner questions about Teensy 4.0 in conjunction with the FlexCAN_T4 library, since my attempts to read CAN signals have not been successful so far.My experimental setup is as follows:
    - Highspeed CAN input (500 kBaud) at the Waveshare SN65HVD230 CAN transceiver board.
    - CAN Transceiver Board is connected to a Teensy 4.0: 3.3V --> 3.3V | GND --> GND | CAN-TX --> CAN-RX (Pin 23) | CAN-RX --> CAN-TX (Pin 22)
    - 120 Ohm resistor between CAN-H and CAN-L on CAN Transceiver Board
    Physically the CAN was also checked by Picoscope -> transmitted signals arrive at CAN-H/CAN-L header
    As a basis the read_two_channels - program was used:
    #include <FlexCAN_T4.h>
    FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> can1;
    CAN_message_t msg;
    void setup(void) {
      can1.begin();
      can1.setBaudRate(500000);
      if ( can1.read(msg) ) {
        Serial.print("CAN1 ");
        Serial.print("MB: "); Serial.print(msg.mb);
        Serial.print("  ID: 0x"); Serial.print(msg.id, HEX );
        Serial.print("  EXT: "); Serial.print(msg.flags.extended );
        Serial.print("  LEN: "); Serial.print(msg.len);
        Serial.print(" DATA: ");
        for ( uint8_t i = 0; i < 8; i++ ) {
          Serial.print(msg.buf[i]); Serial.print(" ");
        Serial.print("  TS: "); Serial.println(msg.timestamp);
    Interesting is that my CAN transmitter (restbus simulation from Windows PC) shows a Not Ackknowledge Error, which normally means that there is no receiver on the bus.
    The serial output remains empty.
    Do I have to set anything else to listen to my CAN messages?
    When do I use FIFO, when do I use mailboxes?
    What influence do the RX_SIZE and TX_SIZE parameters have?
    Do you see any discrepancies in my setup?
  16. #816
    Hi Samduino,
    The data lines from Teensy to CAN transceiver should be:
    CAN-RX --> CAN-RX | CAN-TX --> CAN-TX
    They don't cross over like a serial connection.
    The ACK bit is sent by the Teensy hardware, so without proper connection between Teensy transceiver, incoming frames cannot be received or ACK'd.
  17. #817
    Jan 2015
    UK
    174
    You need two or more active nodes on a CAN network in order to function correctly.
  18. #818
    Sep 2021
    14
    Hi msadie,
    in fact youre right - thanks! Now I am getting Data
    I tried it before, but there was presumably another mistake
  19. #819
    Sep 2021
    14
    Hey guys,
    My intention is to build a gateway that splits a CAN-FD frame into several CAN frames.
    My approach would be:
    If there is a CAN-FD frame with DLC = 15 (64 byte payload), I divide the content into 8 CAN frames with 8 bytes each, with DLC = 14 in 6 frames, with DLC = 13 in 4 frames and so on.
    My question is whether there is already a function for this that I could use?
    Could someone also explain to me how the onReceive function and the events () function work?
    Help is very much appreciated. Thanks in advance
  20. #820
    Dec 2016
    Montreal, Canada
    3,871
    there are private functions the library uses internally to convert length to dlc for transmit and dlc to length for receive. You can move them to public or copy them to your own sketch.
    onReceive callback is when your receiving data from interrupts, unless when you are polling you can send the frames to that callback as well.
    events() is used for dequeuing transmits or interrupt based messages in queue towards the callback.
    FD mode requires events() for interrupt receptions to work, as direct firing wasn't implemented yet like the CAN2.0 side
  21. #821
    Sep 2021
    14
    Perfect, the len_to_dlc-functions helps me to go on
    Only for my understanding:
    - receiving data from interrupts happens when using onReceive() instead of the read()?
    - events() is the basis of onReceive() because it cares about routing e.g. CAN-FD Frames (which triggered interrupts) to the callback function (e.g. the canSniff-function)?
    I'm sorry about maybe very basic questions, but I'm new to C++
    Do you mean with "direct firing" the read()-function or FIFO registers? Because I thought I've read that CAN-FD does not support FIFO...
  22. #822
    Dec 2016
    Montreal, Canada
    3,871
    correct. CANFD has no FIFO on this processor. canSniff is just a function called when set in onReceive when a frame is received via interrupts. You can also if wanted, if not using interrupts, poll the frames via read() and send it to same function
    Can0.read(msg);
    canSniff(msg);
    If you are polling, you don't need to use onReceive at all. It's there for interrupt usage
    direct firing I meant the callback gets fired immediately with data, without using the queue system in the library
  23. #823
    Sep 2021
    14
    Alright, thanks.
    I have another question regarding the mailboxes for transmitting.
    Now my program is able to split a CAN-FD message into the right amount of necessary CAN messages with the corresponding payload. The problem is that when I am calling CAN.mailboxStatus() the content does not change fitting to the incoming CAN-FD payload. It contains still the payload from the first time I started the program
    Do I have to delete the payload of the mailbox after calling CAN.write() again?
  24. #824
    Dec 2016
    Montreal, Canada
    3,871
    mailboxStatus() is there for legacy CAN3 CAN2.0 mode, the CANFD version is not added yet
  25. #825
    Sep 2021
    14
    I don't really understand this. Does it mean that I can use mailboxStatus() only by sending or receiving CAN at CAN3 (Pins 30, 31 on Teensy 4.0)?
    In the following serial-prints maybe I can show my problem in a better way:
    Incoming CAN-FD message:
    MB 1  OVERRUN: 0  LEN: 48 EXT: 0  EDL: 1 TS: 40614 ID: 2 Buffer: FF 1 2 3 4 5 6 8 2 A 0 0 0 0 0 0 3 B 0 0 0 0 0 0 4 C 0 0 0 0 0 0 5 D 0 0 0 0 0 0 6 E 0 0 0 0 0 0
    Now my program splits the CAN-FD frame in 6 CAN frames with increasing IDs (1 to 6) and sends them out with CAN.write(msg_c);
    Mailbox status after second time receiving the CAN-FD Frame above - remember I sent 2 times each seperate generated CAN-frame (so in theory 12 sent CAN-frames).
    You clearly see, that it fills up the mailboxes until there is no free left.
    ID: 6 Buffer: 6 E 0 0 0 0 0 0
    FIFO Disabled
    	Mailboxes:
    		MB0 code: RX_EMPTY	(Standard Frame)
    		MB1 code: RX_EMPTY	(Standard Frame)
    		MB2 code: RX_EMPTY	(Standard Frame)
    		MB3 code: RX_EMPTY	(Standard Frame)
    		MB4 code: RX_EMPTY	(Extended Frame)
    		MB5 code: RX_EMPTY	(Extended Frame)
    		MB6 code: RX_EMPTY	(Extended Frame)
    		MB7 code: RX_EMPTY	(Extended Frame)
    		MB8 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x1)(Payload: FF 1 2 3 4 5 6 8)
    		MB9 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x2)(Payload: 2 A 0 0 0 0 0 0)
    		MB10 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x3)(Payload: 3 B 0 0 0 0 0 0)
    		MB11 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x4)(Payload: 4 C 0 0 0 0 0 0)
    		MB12 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x5)(Payload: 5 D 0 0 0 0 0 0)
    		MB13 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x6)(Payload: 6 E 0 0 0 0 0 0)
    		MB14 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x1)(Payload: FF 1 2 3 4 5 6 8)
    		MB15 code: TX_DATA (Transmitting)(Standard Frame)(ID: 0x2)(Payload: 2 A 0 0 0 0 0 0)
    Next strange behavior is that my picoscope monitors continuously the first frame [(ID: 0x1)(Payload: FF 1 2 3 4 5 6 8)].
    There my question, do I have to delete the payload of the mailbox after calling CAN.write() again or is there another reason?
    Maybe I should try FIFO?
    Thanks for help!
