I received the MCP2562-E/SN transceivers used on skpang's board last week and have spent a fair amount of time experimenting. So far the MCP2562-E/SN acts identically to the other three chips I tried before.
Just for recap: using FIFO interrupt callback on CAN2 to transmit sequentially on CAN1 eventually gets stuck indefinitely with a message "transmitting" in the mailbox.
The original setup included a custom PCB and recorded messages being played back onto CAN2 with a Vector VN1610. Item by item I simplified this setup, but never saw any improvement.
The current setup has moved to a breadboard and involves 2x Teensy_4.0:
My hope is that you would be able to confirm this "lockup" behavior with 1x PJRC breakout and 1x skpang breakout.
Teensy #1 code:
Teensy #2 code:
Typical serial output on from Teensy #2:
Thanks, Mike
- Teensy #1 has one MCP2562-E/SN connected to CAN2. It transmits bursts of 14 random messages with periods of bus idle between bursts. Bus load is ~40%.
- Teensy #2 has three MCP2562-E/SN connected to CAN1-3. Messages from Teensy #1 are received FIFO on CAN2 and sequentially transmitted on CAN1. CAN1 is connected to CAN3 to provide ACK.
Teensy #1 code:
#include <FlexCAN_T4.h>
#include <elapsedMillis.h>
FlexCAN_T4<CAN2, RX_SIZE_256, TX_SIZE_32> VCAN;
CAN_message_t msgRand;
elapsedMicros usBurstIntervalTimer;
uint8_t burstCount = 14;
VCAN.begin();
VCAN.setClock(CLK_60MHz);
VCAN.setBaudRate(500000);
VCAN.setMaxMB(32);
for (int i; i < 32; i++) {
VCAN.setMB((FLEXCAN_MAILBOX)i, TX);
randomSeed(0);
usBurstIntervalTimer = 0;
if ( usBurstIntervalTimer >= 6000 ) { // Burst interval timer expired
for (int i = 0; i < burstCount; i++) {
msgRand.id = random(0x100, 0x7FF);
msgRand.len = random(1, 8);
msgRand.buf[0] = random(0, 255);
VCAN.write(msgRand);
Teensy #2 code:
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_64> LCAN;
FlexCAN_T4<CAN2, RX_SIZE_256, TX_SIZE_16> VCAN;
FlexCAN_T4<CAN3, RX_SIZE_256, TX_SIZE_16> LCAN3;
elapsedMillis msPrintTimer;
uint32_t rxCounterVCAN = 0;
uint32_t rxCounterLCAN3 = 0;
Serial.begin(500000);
// Setup VCAN (CAN2)
VCAN.begin();
VCAN.enableFIFO();
VCAN.enableFIFOInterrupt();
VCAN.onReceive(canV2L);
// Setup LCAN (CAN1)
LCAN.begin();
LCAN.setClock(CLK_60MHz);
LCAN.setBaudRate(500000);
// Setup LCAN3 (CAN3) - needed to ACK TX msgs from LCAN (CAN1)
LCAN3.begin();
LCAN3.setClock(CLK_60MHz);
LCAN3.setBaudRate(500000);
LCAN3.enableFIFO();
LCAN3.enableFIFOInterrupt();
LCAN3.onReceive(rxIncLCAN3);
msPrintTimer = 0;
VCAN.events();
LCAN.events();
LCAN3.events();
if ( msPrintTimer > 1000 ) {
msPrintTimer = 0;
Serial.print("RX Count VCAN: "); Serial.print(rxCounterVCAN);
Serial.print(" LCAN3: "); Serial.println(rxCounterLCAN3);
void canV2L(const CAN_message_t &msg) {
CAN_message_t myMsg;
myMsg = msg;
myMsg.seq = 1;
LCAN.write(myMsg);
rxCounterVCAN++;
void rxIncLCAN3(const CAN_message_t &msg) {
rxCounterLCAN3++;
RX Count VCAN: 5 LCAN3: 4
RX Count VCAN: 2338 LCAN3: 2338
RX Count VCAN: 4662 LCAN3: 4662
RX Count VCAN: 6997 LCAN3: 6996
RX Count VCAN: 9324 LCAN3: 9324
RX Count VCAN: 11652 LCAN3: 11651
RX Count VCAN: 13986 LCAN3: 13986
RX Count VCAN: 16310 LCAN3: 16310
RX Count VCAN: 18646 LCAN3: 18644
RX Count VCAN: 20972 LCAN3: 20972
RX Count VCAN: 23298 LCAN3: 23297
RX Count VCAN: 25634 LCAN3: 25634
RX Count VCAN: 27958 LCAN3: 27958
RX Count VCAN: 30291 LCAN3: 30289
RX Count VCAN: 32620 LCAN3: 32620
RX Count VCAN: 34944 LCAN3: 34944
RX Count VCAN: 37282 LCAN3: 37281
RX Count VCAN: 39606 LCAN3: 37939
RX Count VCAN: 41936 LCAN3: 37939
RX Count VCAN: 44268 LCAN3: 37939
RX Count VCAN: 46592 LCAN3: 37939
RX Count VCAN: 48927 LCAN3: 37939
Thanks, Mike
