Results 1 to 2 of 2
Thread: Duplicating Arduino example code to work for 5 piezo mics
    May 2019
    1
    I'm currently working on a uni project in which I'm making a glove with piezo sensors on the fingertips that output a MIDI note into Ableton. I've found some example code in Arduino which works perfectly for one piezo, but I'm not sure how to change the code in a way that will allow five different piezos to output five different MIDI notes. I'll post the example code below for reference -
    const int channel = 10; // General MIDI: channel 10 = percussion sounds
    const int note = 36; // General MIDI: note 38 = acoustic snare
    const int analogPin = A0;
    const int thresholdMin = 60; // minimum reading, avoid noise and false starts
    const int peakTrackMillis = 12;
    const int aftershockMillis = 25; // aftershocks & vibration reject
    while (!Serial && millis() < 2500) /* wait for serial monitor */ ;
    Serial.println("Piezo Peak Capture");
    int piezo = analogRead(analogPin);
    peakDetect(piezo);
    // Add other tasks to loop, but avoid using delay() or waiting.
    // You need loop() to keep running rapidly to detect Piezo peaks!
    // MIDI Controllers should discard incoming MIDI messages.
    // http://forum.pjrc.com/threads/24179-...ses-midi-crash
    while (usbMIDI.read()) {
    // ignore incoming messages
    void peakDetect(int voltage) {
    // "static" variables keep their numbers between each run of this function
    static int state; // 0=idle, 1=looking for peak, 2=ignore aftershocks
    static int peak; // remember the highest reading
    static elapsedMillis msec; // timer to end states 1 and 2
    switch (state) {
    // IDLE state: wait for any reading is above threshold. Do not set
    // the threshold too low. You don't want to be too sensitive to slight
    // vibration.
    case 0:
    if (voltage > thresholdMin) {
    //Serial.print("begin peak track ");
    //Serial.println(voltage);
    peak = voltage;
    msec = 0;
    state = 1;
    return;
    // Peak Tracking state: capture largest reading
    case 1:
    if (voltage > peak) {
    peak = voltage;
    if (msec >= peakTrackMillis) {
    //Serial.print("peak = ");
    //Serial.println(peak);
    int velocity = map(peak, thresholdMin, 1023, 1, 127);
    usbMIDI.sendNoteOn(note, velocity, channel);
    msec = 0;
    state = 2;
    return;
    // Ignore Aftershock state: wait for things to be quiet again.
    default:
    msec = 0; // keep resetting timer if above threshold
    } else if (msec > aftershockMillis) {
    usbMIDI.sendNoteOff(note, 0, channel);
    state = 0; // go back to idle when
    Apologies if I've been confusing, coding and Arduino are still very new to me!
    Any help is very greatly appreciated.
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,112
    I once wrote an extension to Paul's single-piezo example code for someone....
    https://forum.pjrc.com/threads/49815...l=1#post169389
    I never tested it but others said it works.
