redeclared as different kind of symbol only on Teensy 3.
2n3055
This code compile without error on Teensy2 but not with Teensy3 ?
What is wrong ?
byte index = 0;
char message[10];
strcpy(message,"123456");
  Serial.print("\r\nmessage ");
  while (message[index] != '\0')
    Serial.print(message[index]);
    index++;
index() is defined as a function in string.h. This function seems to be deprecated but it looks like the ARM compiler used for Teensy 3 still implements it. I assume that the AVR compiler for Teensy2 does not implement it, so that your example compiles for a Teensy2.
Just rename your variable to something else and it will compile.
