Results 1 to 3 of 3
Thread: High Speed counting using interrupts
    I want to count 4 speed channels of rpm
    each sensor has 360 pulses
    if anyone is interested the code below will update 100 times a second and seems pretty accurate
    So far i have only been able to count on one channel - i will program another teensy to pulse 4 channels
    the code works up to approx 270 khz plenty fast enough for me
    is this a good strategy for counting 4 speed channels ?
    uint8_t pulse_pin1 = 11;
    uint8_t pulse_pin2 = 12;
    unsigned long NoOfPulses1=360;
    unsigned long NoOfPulses2=360;
    unsigned long pulseCount1=0;
    unsigned long pulseCount2=0;
    unsigned long Period1=0;
    unsigned long Period2=0;
    unsigned long Freq1=0;
    unsigned long Freq2=0;
    unsigned long RPM1=0.000;
    unsigned long RPM2=0.000;
    unsigned int DataStamp = 0;
    unsigned int NowStamp = 0;
        pinMode(pulse_pin1, INPUT_PULLUP);
        pinMode(pulse_pin2, INPUT_PULLUP);
        delay(2000);
        DataStamp = micros();
        attachInterrupt(digitalPinToInterrupt(pulse_pin1), pulseCounting1, RISING);
        attachInterrupt(digitalPinToInterrupt(pulse_pin2), pulseCounting2, RISING);
    void pulseCounting1()
      pulseCount1++;
    void pulseCounting2()
      pulseCount2++;
     if (millis() > (DataStamp/1000 + 99)) {   // 100 samples per second
         NowStamp = micros();
         if (pulseCount1 > 0)  {
          Period1 = ( (NowStamp - DataStamp) ) ;
          Freq1 = ((pulseCount1 * Period1)/10000) ;
          RPM1 = (Freq1 * 60) / NoOfPulses1 ;
          Serial.print("Freq 1: ");Serial.println(Freq1);
          Serial.print("RPM 1: ");Serial.println(RPM1);
          pulseCount1=0;
         if (pulseCount2 > 0)  {
          Period2 = ( (NowStamp - DataStamp) ) ;
          Freq2 = ((pulseCount2 * Period2)/10000) ;
          RPM2 = (Freq2 * 60) / NoOfPulses2 ;
          Serial.print("Freq 2: ");Serial.println(Freq2);
          Serial.print("RPM 2: ");Serial.println(RPM2);
          pulseCount2=0;
    Interestingly - I tried running the code on a arduino nano and a Teensy 2.0
    the code did not run correctly and it gave a pulse count of one each time
    am i right to assume the processor is too slow to read and compute the time period using micros() ?
    this code worked on the Teensy 2.0
    not as accurate because the time interval uses millis() instead of micros()
    //uint8_t pulse_pin1 = 11;
    //uint8_t pulse_pin2 = 12;
    uint8_t pulse_pin1 = 6;
    uint8_t pulse_pin2 = 7;
        delay(2000);
        DataStamp = millis();
        //analogWriteResolution(16);
        //analogWriteFrequency(pulse_pin, 700000.0L);
        //analogWrite(pulse_pin, 32000);
      pulseCount1++;
       digitalWrite(13, HIGH);
      pulseCount2++;
      //Serial.print("Count 2: ");Serial.println(pulseCount2);
     if (millis() > (DataStamp + 9)) {
         NowStamp = millis();
          Freq1 = ((pulseCount1 * Period1)* 10) ;
          Serial.print("Pulses 1: ");Serial.println(pulseCount1);
          Serial.print("Period 1: ");Serial.println(Period1);
          Serial.print("Freq 1 : ");Serial.println(Freq1);
          Serial.print("RPM 1 : ");Serial.println(RPM1);
          pulseCount1=0;
          Freq2 = ((pulseCount2 * Period2)* 10) ;
          RPM2 = (Freq1 * 60) / NoOfPulses2 ;
          Serial.print("Pulses 2: ");Serial.println(pulseCount2);
          Serial.print("Period 2: ");Serial.println(Period2);
          Serial.print("Freq 2 : ");Serial.println(Freq2);
          Serial.print("RPM 2 : ");Serial.println(RPM2);
          pulseCount2=0;
