Results 1 to 7 of 7
Thread: teensy 3.2 talkie
    teensy 3.2 talkie
    I have a teensy 3.2, can I make them say sentences with the dac?
    Can you give me some examples? I don't want to use sd cart.
    thank you
    Member propa's Avatar
    Apr 2018
    UK
    93
    Quote Originally Posted by vlelectroniclab View Post
    thank you
    You can, a cursory search yielded this:
    https://youtu.be/RFCJdBVkpE8
    https://rimstar.org/science_electron...ie_library.htm
    You had three wises; you have two left.
    Apr 2018
    UK
    93
    Or you get a specific chip like the ones used in 1980's speak and spell toys and send it a string of ascii from the teensy: http://www.eevblog.com/forum/reviews...ts-of-videos)/
    What program can I use to do text conversion?
    Apr 2018
    UK
    93
    You any good at Python? https://github.com/ptwz/python_wizard
    Apr 2018
    UK
    93
    Sorry that was a bit of a quick response, there's no "easy" way, you need to make a bit stream that is compatible with talkies, there are a few programs or more like command line tools that will allow you to import a wav file and convert it to a stream of bits that you can then playback in an Arduino or teensy.
    See the issue here on the github: https://github.com/going-digital/Talkie/issues/4
    That lists a few solutions to packaging up a wav file into a bunch of bits
    I do not know
