Hello everyone , so I'm trying to make a project which involves the use of accelerometer data with the teensy 3.2 . The accelerometer I'm using is adxl343 which is similar to adxl345 but I've tried all kinds of libraries and sample codes I'm not able to receive any sort of data from the accelerometer. It only shows either a bad wiring error or it shows all 0s for xyz values. Even after using the wire libraries I'm not getting any output. Any sort of help would be appreciated.
Thanks.
Thanks.
