NormalUser
Hi Teensy Community,
I am new to this exciting world and I was wondering if someone could help.
I am trying to basically port all USB0 (Micro-B USB connector) functionality to USB1 (Pins 5V, D-, D+ and G) on the board.
I am using a Teensy 3.5 with a quick and easy jumper wire modification, I connected pin 3 and pin 4 together on TPD3S014.
The board is powering up but I have not USB communication, and it makes sense since the USB data is going to K1 and J1 instead of H1 and H2.
So, how do I redirect Teensy to operate using USB1 instead of the Micro-B connector (USB0)? Can this be done?
I am trying to avoid using a USB cable to communicate with, I want to go with a normal 4 pin connector/cable instead.
Thanks in advance,
Normal.User.
Thanks in advance,
Normal.User.
