Hi guys,
I've just received that CAN transceivers (hope they are ok for Teensy!):
https://www.ebay.it/itm/2pcs-SN65HV...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
I've connected the Teensy v3.6 CAN-TX pin with the CTX of transceiver and Teensy CAN-RX to the CRX...
Can you please point me to the best CAN library to use? I need to get connected to the CAN bus of my bike at 500kbps and ask with OBD messages for RPM, TPS and ECT...
On my old project with Arduino MEGA I've used the MCP library and it has a loopback mode so I was able to test the connections and SW without connecting physically to the CAN bus of the bike: in loopback mode everything is sent to the CAN bus is received back.... is there a similar feature?
Have I need the 120ohm resistor with Teensy?
Sorry, I'm new on CAN
