Results 1 to 5 of 5
Thread: ASCII Pinmapping for Teensy 3.6 ?
    is there a textual (ASCII) chart of the pinmapping/funtions of the pins of the Teensy 3.6 ?
    (searching text in images is compilcated...)
    Thanks a lot for any help in advance!
    Cheers!
    Meino
    20,068
    The defines in core_pins.h are probably the closest thing.
    https://github.com/PaulStoffregen/co...y3/core_pins.h
    Good morning Paul,
    This forum is so much better than that one which had "supported" my previous Cortex M4 board!
    Glad to have bought a Teensy! Really!
    Thanks for the link...will check that!
    Cheers!
    Meino
    2,956
    If you wanted to compare Teensy's at the Arduino pin level (rather than the internal level), I created the following google spreadsheet that tries to compare the Teensy 3.0, 3.1/3.2, 3.5, 3.6, and LC boards for my own uses:
    Hi Michael,
    not exactly what I wanted but ... OH YEAH! what a "wall of information" (meant positively 100%!) !!!
    Thanks a LOT!
    Cheers!
    Meino
