Results 1 to 8 of 8
Thread: Main chip of Teensy 3.2 Overheating
    May 2019
    4
    Hello , I have some problem on my project. I build the project to Send Value by Serie Communication like the picture that I attachClick image for larger version.
    I use external Power and I already cut pad between Vin and VUSB . But Sometime my Teensy getting hot some device and Dead . Some Device It's working but Heating around 70 Celcuis at Main chip .I don't know why . Could anyone can explain why ? .
    I read some article they said about Overcurrent / Overvoltage at I/O pin , Power Surge or ESD . Please Help
    8,380
    The picture doesn't suggest how the LED strips get power and GND. Do the high temps continue when the LEDS are disconnected?
    May 2019
    4
    I use power from Buck Converter to give Teensy and LED Strip (Same Source).After Teensy getting hot It's still hot all the time even I disconnect all component.
    May 2019
    4
    Here is my Schematic.
    8,380
    That may help somebody spot something - a photo of the actual build might as well.
    Question picture in p#1 show a number 'n'. Will this happen with a single unit - or only multiples connected? Does high heat or Death follow any of the buck converters?
    When it gets hot and everything disconnected - and it stays hot - if unplugged and repowered does it go to normal operating temp?
    I've not gotten any Teensy processor that hot - not sure what could be in the code that would do that. Might be interesting to pick a free pin for INPUT_PULLUP and then run the code normally when it is HIGH and when it goes low shutdown all the code except go to a simple blink loop and toggle the pin 13 LED and see if the temp drops.
    19,929
    What is this part?
    In the past, we've seen trouble caused by certain step-down power supplies, especially Traco. Many of them require extra capacitors at their input and output. The Traco one in particular has a misleading datasheet which says the input cap is only needed if using a higher input voltage. Testing has shown it becomes horribly unstable without the capacitor in certain situations, like a battery that's low or with lengthy wires connecting to the input power.
    Senior Member crees's Avatar
    Dec 2016
    Utah
    143
    Others can chime in and verify my assumptions but I see a potential ground loop issue between your different teensy that could cause power to source back and cause damage. I would look at using rs485 chips to interface your teensy and then utilize dc dc isolation with otpoisolators. This will keep the ground loops from damaging your teensy
    May 2019
    4
    What is this part?
    This is Volt Regulator I buy from aliexpress
    https://th.aliexpress.com/item/Mini-...OrigTitle=true
    Could you suggest me the good one of regulator . Thank you Sir.
