Hi all, got a quick question. The schematic for T3.2 shows a fuse between the Micro-USB connector and the VIN / VUSB pins (as well as the voltage regulator):
There are times, especially during initial project development, where I want to power both the Teensy and something else (say an LED strip) from the Micro-USB connector. It’s convenient to test things by picking up the 5V from VIN pin rather than setting up a separate power supply. So, finally, the question: how much current can I safely push through that fuse?
Thanks.
Thanks.
