Results 1 to 3 of 3
Thread: Potentiometers?
    Potentiometers?
    what is a recommended value of the resistance of a potentiometer, which I want to
    use to be read by the ADC of a battery driven Teensy 3.6 to influence parameters
    of a program ?
    I want to add a couple of potentiometers...not only a single one...
    Thanks for any help in advance!
    Cheers
    Meino
    Feb 2014
    Colmar, France
    2,442
    Due to the input impedance of the SAR ADCs which varies during the conversion cycle, a relatively low resistance of the potentiometer is required. An application note from NXP recommends 5k or 10k. In addition, they recommend adding a 10nF capacitor from the pot wiper to GND, placed as close as possible to the processor’s analog input pin.
    Hi Theremingenieur,
    thanks for your help!
    5k...10k is quite low for a battery powered device with lot of pots...
    Will see...
    Cheers!
    Meino
