I want to make a circuit that does not include a teensy, despite my drive to include a teensy in everything even when its not called for. The goal is that when a vibration sensor closes (when it is moved, it closes its contacts), it triggers a transistor for a period of time (I'd like it to remain closed for an hour or two, preferably two), then it opens again until triggered by the vibration sensor again.
The point of this is it is an auto-shutoff, in case someone forgets to turn off whatever the transistor is in line with while that device is not in use (not being handled).
I was hoping something simple like a 555 timer (I know nothing of them but I don't think that'd do it, just an example of what kind of simple I am looking for) could do the trick. A microcontroller would be fine, but I suspect the power usage would be higher than I'd like for most projects which will be in the 3-6mA range at 4.5v-3v. I have some wiggle room for how I power things, but I'd like the option of both without adding in a lot of components for a voltage regulator. Right now, everything I have in mind would run on either 3AAA or a CR2032.
Cheap and compact is my main goal.. This will all be dead-bugged or on a bit of project board. I'm not at the custom-pcb level yet.
Since this is my favorite forum for people who know way more than I do about these sorts of things I thought I might as well ask here.
