Results 1 to 3 of 3
Thread: I programed a interrupt on pins 3 and 4
    I programed a interrupt on pins 3 and 4 and now I can't program other sketch, the program button does not respond.
    What will be the possible problem?
    How can I program other sketch?
    Reprogram the bootloader?
    I programmed the sketch below into a teensy 3.2 and after that I started having the problem. It used to be normal.
    /* Encoder Library - Basic Example
    http://www.pjrc.com/teensy/td_libs_Encoder.html
    #include <Encoder.h>
    // Change these two numbers to the pins connected to your encoder.
    // Best Performance: both pins have interrupt capability
    // Good Performance: only the first pin has interrupt capability
    // Low Performance: neither pin has interrupt capability
    Encoder myEnc(3, 4);
    // avoid using pins with LEDs attached
    Serial.println("Basic Encoder Test:");
    long oldPosition = -999;
    long newPosition = myEnc.read();
    if (newPosition != oldPosition) {
    oldPosition = newPosition;
    Serial.println(newPosition);
    19,929
    Quote Originally Posted by Dianderson Mendonša View Post
    How can anyone answer, when we don't even know which Teensy you're using, nor anything about this program other than it used interrupts (which have been used successfully by many thousands of other people).
    Sorry for my lack of attention.
