Results 1 to 6 of 6
Thread: Hitting Watchdog Too Often
    Why does hitting the watchdog too often not reset the watchdog timer? The following code causes a reset on the Teensy 3.2.
    #include <Adafruit_SleepyDog.h>
      Watchdog.enable(5000);
      Serial.setTimeout(10);
      Serial.println("Setup");
      Watchdog.reset();
      // comment the following line to cause a reset.
      delay(1000); Serial.println(".");
    Apr 2018
    3
    Try with:
    elapsedMillis wdMillis;
      if (wdMillis > 4900)
          wdMillis = 0;
          Watchdog.reset();
    I understand that the watchdog is typically reset just before the timer expires. I am more interested in why it doesn't work if it is reset too often.
    May 2017
    207
    The underlying ARM processor implements a windowed watchdog, and will reset on too fast or too slow watchdog service intervals. It looks like the default value for the lower counter is 16 ( which may or may not represent 16 ms. You can test that with your program ).
    Edit: Looking further it appears the windowed mode is not enabled in the status register.
    8,557
    With nothing else in loop() that reset() is being called at least a couple hundred thousand times per second on a T_3.2.
    I put the code in a sketch and without waiting at least/about 970 microseconds with a delay between calls the watchdog would restart the processor as if watchdog was not reset().
    Since I had to download the library I glanced at it - the reset() call :: Disables interrupts, writes the needed values to reset the timer, then Enables interrupts. That interrupt toggle could be generally disruptive of normal operation and function.
    The watchdog code/implementation seems to deal with millisecond time intervals and calling it every few microseconds … up to that 970 us … is just not how it was designed to be used - or perhaps as @rcarr notes perhaps updates too fast are defined as another way the watchdog defines failure - the processor docs would detail that.
    20,068
    This is indeed a strange problem. The watchdog somehow getting into windowed mode does seem like the only plausible explanation, but I can't see how that could be happening.
    I am currently at Maker Faire in San Mateo, so writing this from my laptop in a hotel room without access to my workbench & tools. If I miss this when I get back on Tuesday, please ping me with a reminder. I'd really like to dig into why this is happening, when I have access to my tools.
