I am trying to build a theremin where i'm controlling the amplitude of a sine wave based on input from a photoresistor (and frequency based on ultrasonic distance sensor).
I am getting really bad noise when the photoresistor input is in the low to middle range. Input from other sensor (ultrasonic distance) does not cause this problem. Any guidance will be appreciated.
code:
[/CODE]
code:
[CODE]#include <Audio.h>
//Ultrasonic sensor HC-S04 stuff
#define trigPin 0
#define echoPin 1
#define photoResistorPin 8
#define led 13
long distance, duration;
AudioSynthWaveform sine1; //xy=245,312
AudioOutputUSB usb1; //xy=841,291
AudioOutputAnalog dac1;
AudioOutputI2S i2s1; //xy=873,209
AudioConnection patchCord1(sine1, 0, i2s1, 0);
AudioConnection patchCord2(sine1, 0, i2s1, 1);
AudioConnection patchCord3(sine1, 0, usb1, 0);
AudioConnection patchCord4(sine1, 0, usb1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=469.00000762939453,382.00000762939453
float noteFrequency;
float noteAmplitude;
double amplitudeVal;
long sensorVal;
long sensor1Val;
int key;
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(led, OUTPUT);
sine1.begin(WAVEFORM_SINE);
AudioMemory(20);
sgtl5000_1.enable();
sgtl5000_1.volume(0.85);
//>>>>>>>>>>>>>> Reading the ultra sonic sensor<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
long sensorReading()
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = duration/58.2; //for cm
Serial.println("Distance ");
Serial.println(distance);
return distance;
//>>>>>>>>>>>>>>>>>>>>> Key Mapping <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
// >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Translating sensor reading to frequency>>>>>>>>>>>>>>>>>>>>>>
float frequencyCalculator()
if((distance>50))
noteFrequency = 0;
if((distance<=5))
noteFrequency = 261; //middle C
else if((distance>5)&&(distance<=10))
noteFrequency = 293; //D
else if((distance>10)&&(distance<=15))
noteFrequency = 329; //E
else if((distance>15)&&(distance<=20))
noteFrequency = 349; //F
else if((distance>20)&&(distance<=25))
noteFrequency = 391; //G
else if ((distance>25)&&(distance<=30))
noteFrequency = 440; //A
else if ((distance>30))
noteFrequency = 494; //B
return noteFrequency;
// >>>>>>>>>>>>>>>>>>>>>> Envelope altering >>>>>>>>>>>>>>>>>>>>>>>>>
// >>>>>>>>>>>>>>>>>>>>>> Amplitude maping >>>>>>>>>>>>>>>>>>>>>>>>>
float amplitudeMapping()
double z;
z = analogRead(photoResistorPin);
amplitudeVal = z/1000;
Serial.println("aplitude is ");
Serial.println(amplitudeVal);
return amplitudeVal;
//>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> generating the sound<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
void soundGen()
{sensorReading();
noteFrequency = frequencyCalculator();
noteAmplitude = amplitudeMapping();
sine1.frequency(noteFrequency);
sine1.amplitude(noteAmplitude);
if(noteFrequency == 0)
//Serial.print("\nDoing nothing \n");
digitalWrite(led,LOW);
// >>>>>>>>>>>>>>>>>>>>>>>>>>> Main Loop <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
soundGen();
Serial.print("\n Key: ");
Serial.print(key);
Serial.print(" amplitudeVal: ");
Serial.print(amplitudeVal);
Serial.print(" Frequency: ");
Serial.print(noteFrequency);
