Results 1 to 3 of 3
Thread: TwoWire::endTransmission always return 0
    Senior Member sumotoy's Avatar
    Venezia, Italia
    421
    I'm tying to write a simple I2C scanner but since seems I cannot use the twi.h lib I've tried to use the ability of wire.endTransmission() function to check if device acknoledge.
    small example
     byte  dummy;
      for (char  id=1; id<=100; id++) {
        Wire.beginTransmission(id);
        Wire.write(&dummy, 0);
        if (Wire.endTransmission() == 0)
          Serial.print("[[0x");
          Serial.print(id,DEC);//found
          Serial.print("]] ");
        else {
          Serial.print("0x");
          Serial.print(" ");
    This will aways return all devices found since wire.endTransmission() on teensy 3 always return 0! Th's a way to get around this?
    1,569
    I've figured out a patch which will make the scanner respond properly (at least it does for me).
    Line 150 in teensy\arduino-1.0.2\libraries\Wire\Wire.cpp is a "break;" statement.
    Change it to:
    return 4;
    Pete
    Venezia, Italia
    421
    thanks pete, I will try later, good catch! I think this fix (plus the 3 other possible returns, if applicable) must be included in next release!
