I need to be able to locate an SD card with ejection capability near the edge of a 3D printed housing and thus cannot use the one on the Teensy 3.6. We also have multiple devices connected to the Teensy and are using a number of the pins that would naturally be optimal for an SD card. We tried the following per the Adafruit Micro-SD card (that we are using) configuration:
5V - 5V
GND - GND
CLK - Pin 20 SCK1
DO - Pin 5 MISO1
DI - Pin 21 MOSI1
CS - Pin 31 CS0
After wiring up the card and confirming that the SD card is formatted for FAT32, I note that the LED flashes when I run the slightly customized 'Cardinfo' example - then stops and prints the error,
"Initializing SD card...initialization failed. Things to check:
* is a card inserted?
* is your wiring correct?
* did you change the chipSelect pin to match your shield or module?"
Below is the customized software.
Would appreciate some assistance.
SD card test
This example shows how use the utility libraries on which the'
SD library is based in order to get info about your SD card.
Very useful for testing a card when you're not sure whether its working or not.
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila, pin 7 on Teensy with audio board
** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila
** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila, pin 14 on Teensy with audio board
** CS - depends on your SD card shield or module - pin 10 on Teensy with audio board
Pin 4 used here for consistency with other Arduino examples
created 28 Mar 2011
by Limor Fried
modified 9 Apr 2012
by Tom Igoe
// include the SD library:
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// Teensy audio board: pin 10
// Teensy 3.5 & 3.6 on-board: BUILTIN_SDCARD
// Wiz820+SD board: pin 4
// Teensy 2.0: pin 0
// Teensy++ 2.0: pin 20
const int chipSelect = 31;
//UNCOMMENT THESE TWO LINES FOR TEENSY AUDIO BOARD:
SPI.setMOSI(21); //
SPI.setMISO(5); //
SPI.setSCK(20); //
SPI.setCS(31); //
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print("\nInitializing SD card...");
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card inserted?");
Serial.println("* is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
return;
Serial.println("Wiring is correct and a card is present.");
// print the type of card
Serial.print("\nCard type: ");
switch(card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
default:
Serial.println("Unknown");
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
if (!volume.init(card)) {
Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
return;
// print the type and size of the first FAT-type volume
uint32_t volumesize;
Serial.print("\nVolume type is FAT");
Serial.println(volume.fatType(), DEC);
volumesize = volume.blocksPerCluster(); // clusters are collections of blocks
volumesize *= volume.clusterCount(); // we'll have a lot of clusters
if (volumesize < 8388608ul) {
Serial.print("Volume size (bytes): ");
Serial.println(volumesize * 512); // SD card blocks are always 512 bytes
Serial.print("Volume size (Kbytes): ");
volumesize /= 2;
Serial.println(volumesize);
Serial.print("Volume size (Mbytes): ");
volumesize /= 1024;
Serial.println("\nFiles found on the card (name, date and size in bytes): ");
root.openRoot(volume);
// list all files in the card with date and size
root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
5V - 5V
GND - GND
CLK - Pin 20 SCK1
DO - Pin 5 MISO1
DI - Pin 21 MOSI1
CS - Pin 31 CS0
SD card test
The circuit:
created 28 Mar 2011
by Limor Fried
modified 9 Apr 2012
by Tom Igoe
Sd2Card card;
SdVolume volume;
SdFile root;
SPI.setMOSI(21); //
SPI.setMISO(5); //
SPI.setSCK(20); //
SPI.setCS(31); //
while (!Serial) {
return;
default:
return;
volumesize /= 2;
volumesize /= 1024;
void loop(void) {
