Teensy 3.6: Which CAN0 pins to use?
Bullone
Hy all,
sorry for the stupid question but I've seen that there are CAN0 pins on 3 and 4 and also on 29 and 30 Teensy 3.6 pins.... what is the difference and what is preferred to use?
On the 3.6 there's also 34 and 33 labelled CAN1.
CAN0 on 3+4, and 29+30 just means they're multiplexed to the same bus, you can use either set of pins for that CAN bus, if the process is anything like i2c you may have to tell the teensy which pins to use, but it's likely to default to pins 3 and 4.
