Results 1 to 12 of 12
Thread: Simple WavFilePlayer not working
    May 2019
    2
    Hi
    I have teensy 3.5 and I'm trying to get this sample to work on my board.
    Looks like for some reason, if play method is called teensy somehow hangs. I can't print anything to serial and so on.
    I'm trying to play it on internal DAC from built-in sd card reader.
    I tried multiple computers, sd cards and teensy boards so something must be very wrong somewhere.
    I got this to work back in december 2018, and when I'm using computer which was used back then (so with older version of teensy and arduino), it still works.
    But if I try the same code somewhere else, it does not work
    Can anyone help with that/try if this is working for them?
    I might be missing something obvious here, but I tried many things before posting here.
    I'm using arduino 1.8.9
    Here is the code:
    // Simple WAV file player example
    // Three types of output may be used, by configuring the code below.
    //   1: Digital I2S - Normally used with the audio shield:
    //         http://www.pjrc.com/store/teensy3_audio.html
    //   2: Digital S/PDIF - Connect pin 22 to a S/PDIF transmitter
    //         https://www.oshpark.com/shared_projects/KcDBKHta
    //   3: Analog DAC - Connect the DAC pin to an amplified speaker
    //         http://www.pjrc.com/teensy/gui/?info=AudioOutputAnalog
    // To configure the output type, first uncomment one of the three
    // output objects.  If not using the audio shield, comment out
    // the sgtl5000_1 lines in setup(), so it does not wait forever
    // trying to configure the SGTL5000 codec chip.
    // The SD card may connect to different pins, depending on the
    // hardware you are using.  Uncomment or configure the SD card
    // pins to match your hardware.
    // Data files to put on your SD card can be downloaded here:
    //   http://www.pjrc.com/teensy/td_libs_AudioDataFiles.html
    AudioPlaySdWav           playWav1;
    // Use one of these 3 output types: Digital I2S, Digital S/PDIF, or Analog DAC
    //AudioOutputI2S           audioOutput;
    //AudioOutputSPDIF       audioOutput;
    AudioOutputAnalog      audioOutput;
    AudioConnection          patchCord1(playWav1, 0, audioOutput, 0);
    AudioConnection          patchCord2(playWav1, 1, audioOutput, 1);
    AudioControlSGTL5000     sgtl5000_1;
    //#define SDCARD_CS_PIN    10
    //#define SDCARD_MOSI_PIN  7
    //#define SDCARD_SCK_PIN   14
    #define SDCARD_CS_PIN    BUILTIN_SDCARD
    #define SDCARD_MOSI_PIN  11  // not actually used
    #define SDCARD_SCK_PIN   13  // not actually used
    // Use these for the SD+Wiz820 or other adaptors
    //#define SDCARD_CS_PIN    4
    //#define SDCARD_MOSI_PIN  11
    //#define SDCARD_SCK_PIN   13
      AudioMemory(8);
      SPI.setMOSI(SDCARD_MOSI_PIN);
      SPI.setSCK(SDCARD_SCK_PIN);
      Serial.println("Hello1234");
        // stop here, but print a message repetitively
        while (1) {
      Serial.print("Playing file: ");
      Serial.println(filename);
      // Start playing the file.  This sketch continues to
      // run while the file plays.
      playWav1.play(filename);
      // A brief delay for the library read WAV info
      delay(5);
      // Simply wait for the file to finish playing.
      while (playWav1.isPlaying()) {
      Serial.println("test");
      playFile("ACDC.WAV");  // filenames are always uppercase 8.3 format
    20,556
    Does it play with the 4 sample WAV files?
    2,192
    Curious. I could not get your sketch to work on 1.8.8 with 1.47-beta2, but it works if i go back to 1.8.5/1.42 ??? Under 1.8.8, it seems to hang up the serial port, and i have to push program button to load a new sketch ???
    I also had a simple wav to 2 DACs sketch, and that sketch also hung on 1.8.8, but was ok on 1.8.5 ????
    i was using T3.6 (similar results on T3.5 and T4 beta 2)
    May 2019
    2
    Nope
    i was using T3.6
    It hangs for me the same way. Sometimes I got something on serial if I print it in setup method, probably related with flushing buffers. But playWav1.play(filename); always hangs everything
    2,192
    Using the audio lib example WavFilePlayer on T3.6 to DACs with onboard uSD, the sketch hangs on 1.8.8/1.47-beta2 and on 1.8.7/1.46. As noted, it works on 1.8.5./1.42 and works on 1.8.7/1.45. So something in the upgrade from 1.45 to 1.46 and later broke the WavFilePlayer example on T3.6. ??
    Another data point: instead of the onboard uSD, i hooked up external SD card (SPI 10-13) to T3.6, and the WavFilePlayer sketch worked with 1.8.8/1.47-beta2. So something amiss with onboard uSD driver/lib? (SD listfiles example works just fine with onboard uSD and T3.6 1.8.8/1.47-beta2)
    EDIT: another data point: i replaced the Teensy SD lib on 1.47-beta2 with the the SD lib from 1.45 and the WavFilePlayer example worked on T3.6. So something broke in extending SD lib to support T4 or use of DMA instead of polling? (@WMXZ SDHC update to SD lib in February?)
    EDIT2: on T4B2 WavFilePlayer example "works" from audio adapter uSD (SPI) (I don't have needed SMD resistor for codec, so i get noise through ear buds, but it appears WAV files are playing). If I use BUILTIN_SDCARD, i get no audio and serial monitor never says it's "playing"
    2,330
    OK,
    I tried Cardinfo.ino with T3.6 and SD library (I was working with) it worked.
    T3.5 failed:
    Could not find FAT16/FAT32 partition.
    Make sure you've formatted the card
    Will investigate
    2,330
    Will investigate
    First observations:
    Using CardInfo
    start of program and first sector with T3.5 reads
    Initializing SD card...Wiring is correct and a card is present.
    Card type: SDHC
    88 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88
    a8 98 8b 9e d9 88 88 88 9d fd fc cc 88 88 88 8a
    8b 88 8c fe ff ff 88 a8 88 88 88 d8 b8 8b 88 88
    88 88 88 88 88 88 88 88 88 88 88 88 88 88 dd aa
    it should read (as with T3.6)
    Card type: SDHC
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    20 18 03 16 51 00 00 00 9d 7d 74 c4 00 00 00 82
    03 00 0c fe ff ff 00 20 00 00 00 d8 b8 03 00 00
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 aa
    Same card both T3.6 and T3.5 without pins
    Could it be a HW or NXP problem? (seems 4th bit of SDHC is always high)
    Note, this test is done not with latest ARDUINO / TD version, but the one I used to port SD to T4
    2,192
    With 1.8.8/1.47-beta2 (BUILTIN_SDCARD), cardinfo works for me on T3.5, T3.6, T4B2 with both kingston and SanDisk uSD. The SD file io seems to be working for me, except for the WavFilePlayer -- some funky interaction between audio lib and SD lib -- dueling DMAs?
    2,330
    dueling DMAs?
    SDHC has it own DMA (which according to Bill Greiman is not working ?)
    The original (non T4) version is also using internal DMA,
    continue to look into
    2,330
    the '8' seen in the T3.5 data where indeed the 4th bit, and it was indeed HW, but a contact issue of the sd card holder and not the T3.x board or the processor.
    (It was a fresh T3.5 never used since Kickstarter, sic!)
    So Cardinfo worked with both T3.5 and 3.6. (1.8.8/1.47-beta1)
    2,192
    Were you able to confirm hang with WavFilePlayer for BUILTIN_SDCARD?
    2,192
    maybe this recent post fixes the problem ? https://forum.pjrc.com/threads/56355...ignment-issues
    Further testing required ...
