Results 1 to 3 of 3
Thread: FlexCAN can only send globally defined CAN_message_t
    May 2019
    2
    I'm running into an issue where FlexCAN can only send globally defined can message. Specifically, If I try to Can0.write() a CAN_message_t that is inside of a class, Can0 writes all 0's to the bus. This can be resolved by making the CAN_message_t a global variable.
    Can anyone tell me why this is happening?
    The only difference below is the location of "CAN_message_t msg;"
    (EXAMPLE1) This code works:
    Cansender.cpp
    #include <Arduino.h>
    #include <FlexCAN.h>
    CAN_message_t msg;
    void hexDump(uint8_t dumpLen, uint8_t *bytePtr)
      uint8_t working;
      while( dumpLen-- ) {
        working = *bytePtr++;
        Serial.write( hex[ working>>4 ] );
        Serial.write( hex[ working&15 ] );
      Serial.write('\r');
      Serial.write('\n');
    Cansender::Cansender()
      Can0.begin(500000);
      msg.ext = 0;
      msg.id = 0x100; // 0
      msg.len = 8;
      msg.buf[0] = 100;
      msg.buf[1] = 0;
      msg.buf[2] = 0;
      msg.buf[3] = 0;
      msg.buf[4] = 0;
      msg.buf[5] = 0;
      msg.buf[6] = 0;
      msg.buf[7] = 0;
    void Cansender::sendmsg()
      Can0.write(msg);
      Serial.print("out: "); hexDump(8,msg.buf);
    (EXAMPLE2) This code doesn't work:
    Cansender.cpp
      uint8_t working;
      Serial.write('\r');
      Serial.write('\n');
      Can0.begin(500000);
      CAN_message_t msg;
      msg.ext = 0;
      msg.len = 8;
      msg.buf[0] = 100;
      msg.buf[1] = 0;
      msg.buf[2] = 0;
      msg.buf[3] = 0;
      msg.buf[4] = 0;
      msg.buf[5] = 0;
      msg.buf[6] = 0;
      msg.buf[7] = 0;
      Can0.write(msg);
    Cansender.h
    #ifndef Cansender_h
    #define Cansender_h
    class Cansender
      public:
        Cansender();
        void sendmsg();
        CAN_message_t msg;
    Usage as follows:
    #include <Cansender.h>
      Cansender sender = Cansender();
      sender.sendmsg();
      sender.msg.buf[0]++;
    Feb 2019
    3
    You have "CAN_message_t msg" declared twice. Once in the header file and another in the Cansender constructor. Remove the "CAN_message_t msg" from the constructor and it should work.
    May 2019
    2
    Quote Originally Posted by jdriedger View Post
    Thanks, this fixed it! I haven't noticed this issue with other types of class variables. I understand the mistake now, should have read this first.
