Results 1 to 8 of 8
Thread: Received my audio shield today and want some test to done...but...
    today I reveived my audio shield.
    A sine sweep works fine ... aside from nearly pinching my eardrum...
    Then I wanted to check the wavplayer.
    Accessing the SDcard inserted into the Audios shield works, but the
    sound stutters a lot.
    I changed the header of the file to:
    //#define SDCARD_CS_PIN    10
    //#define SDCARD_MOSI_PIN  7
    //#define SDCARD_SCK_PIN   14
    #define SDCARD_CS_PIN    BUILTIN_SDCARD
    #define SDCARD_MOSI_PIN  11  // not actually used
    #define SDCARD_SCK_PIN   13  // not actually used
    // Use these for the SD+Wiz820 or other adaptors
    //#define SDCARD_CS_PIN    4
    //#define SDCARD_MOSI_PIN  11
    //#define SDCARD_SCK_PIN   13
    and nothing happens anynmore.
    No stuttering...no sound at all ;|
    But also no printing of "Unable to access SD card"...
    What is the problem here?
    Cheers!
    Meino
    Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    79
    The change has the software access the sd card on the Teensy 3.5 or 3.6 and not the one on the audio shield.
    Feb 2014
    Colmar, France
    2,535
    Could be a file format problem. The wav player example can only play 44.1kHz 16bit PCM encoded files. It will stutter or not play if a different format is used.
    Quote Originally Posted by ETMoody3 View Post
    Correct! So I put the SDcard into to Teensy's slot and the reported problem arises.
    How can I fix that?
    The Audio Sample were take from here:
    https://www.pjrc.com/teensy/td_libs_AudioDataFiles.html
    so they should be ok, I think...
    Cheers!
    Meino
    Germany NRW
    5,679
    Usually, this is a) a bad sd card (try a fresh one or reformat with the official format utility) or b) a problem with the hardware- unreliable connections, or too long.
    Mar 2014
    New Ulm, Mn
    79
    Well...if you moved the card and get no playback and no serial response...I gots nothing for you. Should work at least poorly. If it crackles, what Frank says.
    2,202
    Are you using T3.5/T3.6? what version of Arduino IDE and teensyduino?
    How is your audio shield attached to Teensy? (provide photo?)
    WavFilePlayer problem with BUILTIN_SDCARD, see https://forum.pjrc.com/threads/56239...er-not-working
