Results 1 to 6 of 6
Thread: Teensy 3.6 will not run without USB
    Nov 2013
    18
    Hi
    I am using external power so I cut the USB power link at the bottom of the board. The program will run as long as I have the USB cable in and programmed the device once. If I just power up normally it will not run. What have I missed?
    5,989
    Hard to say without seeing code...
    Most common issue is something like: while (!Serial) ;
    21,128
    Also check which version of Teensyduino you have. Click Help > About in Arduino.
    A problem with startup on 3.6 with slow rising power supplies was recently fixed. If you have an older version of the software and one of those slow-starting power supplies, you might be experiencing that problem.
    Nov 2013
    18
    Paul
    I have Teensyduino 1.45
    EDIT: I just noted that the latest version is 1.46. I am downloading
    Oct 2015
    Roma (IT, EU)
    193
    I second KurtE suggestion. Typical case is a loop waiting for Serial Monitor to show up.
    Nov 2013
    18
    Thanks Paul the update did the trick
