Results 1 to 3 of 3
Thread: Problem with X-Plane v11.4.r1 upgrade - Teensy board no longer working
    May 2019
    7
    Using X-plane v11.34.r1 64-bit version of X-Plane on Windows 10. Have been using 3.2 Teensy board with button and rotary encoders for the past 18 months successfully. Now, with the X-Plane version update, the Teensy board is no longer communicating with X-Plane. The board is detected by the Teensy plugin, but none of the buttons or rotary encoder functions work. I do get feedback from the Arduino serial monitor that the buttons are working, but the uploaded sketch/program are not picking up X-Plane datarefs or sending coded commands. Any idea as to what is going on and how I can restore the Teensy board functions? I will be happy to upload the .ino file if necessary.
    Nov 2018
    11
    Wow thats not good. Have been able to get up and running again in 11.34?
    May 2019
    7
    Turns out is was the usb hub causing the problem. When I plugged the Teensy into a separate USB port on the computer, it worked just fine.
