Finally I got exactly the same type of microphone, which is shown on the pages of the Audio Shield at www.pjrc.com.
I soldered the microphone onto the board and wanted to do a quick check, whether the microphone "is online" .
For that, the "Recorder" example sketch was taken and freed from all unecessary stuff (since I have no reliable
SDcard interaction still).
I prints all bytes in the data buffer via the serial monitor.
Or at least...it should...
Unfortunately I can't find the bug...either the microphone is demaged (optical check of the soldering is ok) or...the sketch
is buggy:
Is there anything, which I should program differently so the microphone can be read?
Thanks a lot for any help in advance!
Cheers!
Meino
is buggy:
// Record sound as raw data to a SD card, and play it back.
// Requires the audio shield:
// http://www.pjrc.com/store/teensy3_audio.html
// Three pushbuttons need to be connected:
// Record Button: pin 0 to GND
// Stop Button: pin 1 to GND
// Play Button: pin 2 to GND
#include <Bounce.h>
AudioInputI2S i2s2; //xy=105,63
AudioAnalyzePeak peak1; //xy=278,108
AudioRecordQueue queue1; //xy=281,63
AudioPlaySdRaw playRaw1; //xy=302,157
AudioOutputI2S i2s1; //xy=470,120
AudioConnection patchCord1(i2s2, 0, queue1, 0);
AudioConnection patchCord2(i2s2, 0, peak1, 0);
AudioConnection patchCord3(playRaw1, 0, i2s1, 0);
AudioConnection patchCord4(playRaw1, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=265,212
// For a stereo recording version, see this forum thread:
// https://forum.pjrc.com/threads/46150?p=158388&viewfull=1#post158388
// A much more advanced sound recording and data logging project:
// https://github.com/WMXZ-EU/microSoundRecorder
// https://github.com/WMXZ-EU/microSoundRecorder/wiki/Hardware-setup
// https://forum.pjrc.com/threads/52175?p=185386&viewfull=1#post185386
// which input on the audio shield will be used?
//const int myInput = AUDIO_INPUT_LINEIN;
const int myInput = AUDIO_INPUT_MIC;
// Remember which mode we're doing
int mode = 1; // 0=stopped, 1=recording, 2=playing
AudioMemory(60);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
startRecording();
// If we're playing or recording, carry on...
if (mode == 1) {
continueRecording();
// when using a microphone, continuously adjust gain
if (myInput == AUDIO_INPUT_MIC) adjustMicLevel();
void startRecording() {
Serial.println("startRecording");
mode=1;
void continueRecording() {
if (queue1.available() >= 2) {
byte buffer[512];
// into a 512 byte buffer. The Arduino SD library
// writes are used.
memcpy(buffer, queue1.readBuffer(), 256);
queue1.freeBuffer();
memcpy(buffer+256, queue1.readBuffer(), 256);
int i;
for( i=0 ; i< 512 ; i++ ) {
Serial.print( buffer[i], HEX );
void stopRecording() {
Serial.println("stopRecording");
mode = 0;
void startPlaying() {
Serial.println("startPlaying");
mode = 2;
void continuePlaying() {
if (!playRaw1.isPlaying()) {
mode = 0;
void stopPlaying() {
Serial.println("stopPlaying");
mode = 0;
void adjustMicLevel() {
// TODO: read the peak1 object and adjust sgtl5000_1.micGain()
// if anyone gets this working, please submit a github pull request :-)
Cheers!
Meino
