Page 2 of 2 FirstFirst 1 2
Results 26 to 37 of 37
Thread: WM8731 Board Ideas
  1. #26
    Germany NRW
    5,679
    Not sure.. I'll try to compare the versions before and after t4..
    I don't have hardware for slave-mode. Maybe a T3.2 as master, connected to a second 3.2 or 3.6 as slave? If that works, I can test the T4, too.
  2. #27
    Germany NRW
    5,679
    Hm, I think I have an Idea what the problem is..
    I think, I can repair it tomorrow or on wednesday.
    In addition, for T4, the I2S Slave-code is still a TODO.
    Unfortunately, next week, I'm on a short vacation, and I don't think that I can add the T4 Code this week because I have other TODOs..
  3. #28
    Germany NRW
    5,679
    @Bob, DD4WH's Software can do FM (80-108 MHz), the SGTL5000 gets overclocked to 234KHz in this mode - have you tried to overclock the WM8731?
  4. #29
    Frank, this is all great news. I am available to test changes with T3.6 as slave (or master). I have independent directories for the old and new Teensyduino versions. This makes it easy.
    I will put the overclocking onto the list of tests. With the external MCLK input to the 8731, it is easy to play with that. Bob
  5. #30
    Germany NRW
    5,679
    Got it working with two Teensy 3.6, and TD 1.45, but did not find the bug in the new version so far.
    Well, at least I can say I have a way to test it, and can confirm, the T3.x does not need MCLK in slave mode and works perfectly with another Teensy as Master.
    Going to drink a beer now.
    ... was too hot today.. >40C, (104F)... official all time temperature record here. For tomorrow, even higher temperatures are announced.
    Edit: Tomorrow, I'll give it another try
  6. #31
    Germany NRW
    5,679
    This fix should work for TD 1.47-beta4;
    https://github.com/PaulStoffregen/Au...72dfa4b8418b20
    Fix is for T3 only.
    File is attached.
    New official all time temperature record here... 42,6C
    we are not used to these temperatures here - privately almost nobody has air conditioning. So far it was simply not necessary.
    Attached Files Attached Files
  7. #32
    10,069
    Fix is for T3 only.
    File is attached.
    Recompiled the PT8211 sketch that still works on T4 - and it is silent on T_3.5?
    That is hot 108.68F, we have no AC either - but only a normal 22.222222C here at 72F - which looks like the Normal for there too.
  8. #33
    Germany NRW
    5,679
    There is still an open pullrequest: https://github.com/PaulStoffregen/Au...1eae571d25d9e8
  9. #34
    10,069
    I used post #31 code to build for both.
  10. #35
    Germany NRW
    5,679
    That's an other file
  11. #36
    Thanks, Frank. I just got home and tested this out. But, it did not work for me without adding a
    #if defined(KINETISK)
    at the start of void AudioOutputI2Sslave::config_i2s(void). That seemed to be needed for both your file and the gitHub library and the PR.
    Also, I did not look, but is AudioInputI2Sslave similar as far as a fix?
    Feel free to wait for a break in the weather!! We are thankful that the NW of the US is not seeing your temperatures.
  12. #37
    Now that I have looked, AudioOutputI2S::config_i2s(); is called from AudioInputI2S::begin() and so fixing the former fixes both input and output with the Teensy as I2S slave.
    Also, with the #if defined(KINETISK) of post 36 I am seeing proper compile and run using Teensyduino 1.46 and Arduino 1.8.9.
