Results 1 to 3 of 3
Thread: Serial monitor erratic separation issue
    I have a sketch running on a Teensy 3.2 and sending data to the USB port (used in serial mode). I check the data on the Arduino IDE with the serial monitor / serial tracer.
    My data are basically 12-bit ADC measurements from sliders with a bit of filtering. So I do not expect values outside the 0-4095 range.
    Here's the code:
    #include "MeanFilterLib.h"
    int filtered[12];
    int raw[12];
    int inputs[] = {A9, A8, A6, A5, A4, A3, A2, A1, A10, A11, A14, A0};
    #define LED_PIN 6
    MeanFilter<long> meanFilter[13](200);
     analogReadResolution(12);
     analogWrite(LED_PIN,1);
      for (int i = 0; i < 12; i++) {
        raw[i] = analogRead(inputs[i]);
        filtered[i] = meanFilter[i].AddValue((long)(raw[i]));
        Serial.print(raw[i]);
        Serial.print(",");
        Serial.print(filtered[i]);
    However I have much bigger values, as if most separating commas are lost at some point and most values are merged together two by two. I don't understand what causes this issue.
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,123
    You're printing two values but only one comma with each loop.
    Quote Originally Posted by oddson View Post
    How stupid I am. Thanks a lot oddson!
