Results 1 to 2 of 2
Thread: Teensy 3.5 temperature range
    I would like to use the Teensy 3.5 in an industrial automation project but I am worried that the bottom end of the temperature range (I need to be able to go down to -40 C).
    I have read some threads on this forum about the 3.0/3.2 being used in low temperatures as long as the crystal is replaced:
    https://forum.pjrc.com/threads/23752...ll=1#post32053
    and:
    https://forum.pjrc.com/threads/33525-Temperature-rating
    Is the crystal the limiting factor on the 3.5 as well?
