Linux ModemManager Strikes Back
PaulStoffregen
Looks like ModemManager is again interfering with Teensy on Ubuntu 18.04. Seems Ubuntu recently changed MM's default filter policy to "strict", which causes it to ignore some udev tags. :(
I've updated the 49-teensy.rules file with another tag to hopefully keep MM from messing with Teensy.
https://www.pjrc.com/teensy/49-teensy.rules
To check which filter policy ModemManager is using, run this command:
systemctl status ModemManager | grep filter-policy
If you get nothing, that's a pretty good sign you don't have ModemManager. Running without "| grep filter-policy" can confirm.
Well, that's one less unexplained phenomenon to workaround.
I noticed, I figured it was something low level I did on my system .
Did the new udev rules fully fix the problems on your machine?
It seems to work here on my Ubuntu 18.04 system, though I do still seem some stuff in syslog that ModemManager is taking notice of Teensy.
Well, I haven't copied the new rules in (yet). Instead I removed ModemManager.
It was also keeping a USBTinyISP from working correctly.
Probably a good idea to get the new udev rules anyway. ModemManager always seems to have a way of coming back to cause more trouble.
