Results 1 to 10 of 10
Thread: Troubles Processing MIDI
    May 2018
    Baltimore
    15
    I am having a most perplexing problem with USB MIDI that I'm attempting to solve over video chat for my marketing partner who is a few thousand miles away from me.
    The problem:
    The serial is printing when the device receives a midi note, but there is no audio, which is odd because I used that prototype for a month without this issue cropping up.
    Products in use: Teensy 3.6, PT8211
    Wiring details: the DAC is wired the same as Paul's PT8211 Kit.
    Software setup: Arduino IDE on OSX Mojave with Italian character mapping
    Repro steps: unfortunately, I can't reproduce
    what I've discerned so far to be working:
    - This sketch plays a sine as expected Examples/Audio/HardwareTesting/PT8211Sine, so hardware is presumably okay
    - He downloaded the current Arduino and Teensyduino .dmgs, so the IDE is up to date
    - his configuration matches mine exactly in Arduino's "Tools" menu
    - he can upload sketches successfully
    - his audio and USB cables seem to be fine and we've tried others
    I gave him a stripped down sketch(works for me) to play notes in response to USB MIDI and this is where he hit problems.
    AudioSynthWaveform       waveform1;      //xy=398,195
    AudioEffectEnvelope      envelope1;      //xy=568,200
    AudioMixer4              mixer1;         //xy=709,125
    AudioOutputPT8211           pt8211;           //xy=844,309
    AudioConnection          patchCord1(waveform1, envelope1);
    AudioConnection          patchCord2(envelope1, 0, mixer1, 0);
    AudioConnection          patchCord3(mixer1, 0, pt8211, 0);
    AudioConnection          patchCord4(mixer1, 0, pt8211, 1);
      usbMIDI.setHandleNoteOn(myNoteOn);
      usbMIDI.setHandleNoteOff(myNoteOff);
      AudioMemory(20);
      waveform1.amplitude(1);
      usbMIDI.read();
    void myNoteOn(byte channel, byte note, byte velocity) {
      float freq = 440.0 * powf(2.0, (float)(note - 69) * 0.08333333);
      waveform1.frequency(freq);
      envelope1.noteOn();
      Serial.print("note on:");
      Serial.print("frequency = ");
      Serial.println(freq);
    void myNoteOff(byte channel, byte note, byte velocity) {
      envelope1.noteOff();
    It's almost as if
    envelope1.noteOn();
    isn't doing anything.
    To make matters trickier, he doesn't have access to the Teensy's programming button, so he can't do a hard reset.
    I've tried everything that came to mind to no avail and now I'm reaching out in case this issue is familiar to anyone. Any thoughts or ideas would be greatly appreciated.
    Here's a picture of the device for reference:
    1,249
    When he plays a MIDI note, does he see the output from this?
    If so, does it report the correct frequency?
    Pete
    May 2018
    Baltimore
    15
    He definitely sees the string and I'm double checking with him that the variable is showing up and changing appropriately. I'll post that answer when he gets back to me.
    I'm fairly certain he was, but we ran that at the end of a long day and my memory is failing me.
    thanks for the reply
    May 2018
    Baltimore
    15
    Yes, the frequency is printing for him.
    1,249
    You haven't set any gains for the mixer but for that test you don't need a mixer. Try this (or add gain for the mixer)
    AudioConnection          patchCord3(envelope1, 0, pt8211, 0);
    AudioConnection          patchCord4(envelope1, 0, pt8211, 1);
    Pete
    May 2018
    Baltimore
    15
    Thanks, I sent him a sketch with those changes. will update
    John
    May 2018
    Baltimore
    15
    Sorry for the slow response. He tried the sketch without the mixer and still no sound. I'm truly baffled by this one.
    Chalking this up to gremlins and sending another(less rushed) prototype.
    1,249
    I was able to test your code with a T3.6 and audio board with SGTL5000. I used the MIDI-Ox keyboard on Windows to send MIDI notes to the Teensy via USB. It works, even with the mixer at its default setting.
    Pete
    Jun 2019
    1
    Thanks for this. This worked exactly as expected.
    May 2018
    Baltimore
    15
    I finally solved the mystery. We had different versions of teensyduino. I can't believe I missed that.
    Thanks for your help el_supremo
