Results 1 to 4 of 4
Thread: USB violin (sound over USB without external ADC)
    Mar 2014
    18
    Hi all,
    I'm trying to use the Teensy as a sound card without any physical sound device.
    I read the note that you need to use one non-USB input, but I'm not sure what that means, and I can't get it to work.
    In fact, I can't get any of the examples to work, because they all rely on an external sound board.
    In the end I will be connecting potentiometers to the ADC pins to control the pitch and volume of various notes.
    I may be able to use an ADC input to modulate some synth, but it seems hardcoded to use A2, so that's useless when I need more than one.
    But even if I add an ADC input, I basically get nothing.
    What I want is to be able to just have an USB output and a bunch of synths that I control myself.
    Is that at all possible?
    AudioSynthWaveformSine   sine1;          //xy=680,309
    AudioInputAnalog         adc1;           //xy=708,243
    AudioOutputUSB           usb1;           //xy=968,283
    AudioConnection          patchCord1(sine1, 0, usb1, 1);
    AudioConnection          patchCord2(adc1, 0, usb1, 0);
      sine1.amplitude(1);
      sine1.frequency(600);
    2,222
    First,
    you need to allocate some audio buffers (in setup)
    eg
      AudioMemory(8);
    the number you put here depends on the complexity of your code
    Mar 2019
    Bordeaux / France
    69
    In my case it's about having at least one non usb OUTPUT, and it works fine
    Add
    AudioOutputAnalog dac1;
    to your code
    that should enable USB audio out to live its live...
    2,222
    Quote Originally Posted by Tactif CIE View Post
    Add
    to your code
    Can also be an INPUT as in OP
