Results 1 to 13 of 13
Thread: T3.6 crash when using Serial Port #6 for MIDI - after Teensy Damaged
    May 2018
    Portland, OR USA
    38
    Hi ALL,
    I searched for this potential issue and did not have any luck finding it... if there is info on this please LMK. :-)
    We isolated this issue using example 'Basic I/O' as a starting point (code below). There are four 5-pin MIDI connectors attached to the T3.6. UART1 Pins 0&1 and UART6 Pins 47&48 (with all the resistors, optos, etc..).
    Theory of Operation:
    Receive MIDI msgs into midiA port RX and send MIDI msgs to midiF port TX.
    Tests:
    1) Run code as is and as soon as a MIDI msg is sent the T3.6 hangs. You can hear the USB drop tune from Windows.
    2) Comment out the midiF.send, un-comment midiA.send, and it works.
    3) Change 'Serial6' to 'Serial(2-5)' and move HW RX and TX port wires, all the other ports work.
    MIDI msgs attempted: NoteOn, NoteOff, CC
    Thanks,
    Steve
    Conductive Labs
    #include <MIDI.h>
     // Serial hardware UART 1&6
        MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, midiA);
        MIDI_CREATE_INSTANCE(HardwareSerial, Serial6, midiF);  //  Change 'Serial6' to 'Serial(2-5)' and move HW RX and TX port wires
        Serial.println("Starting up MIDI Serial in1/out6 test");
        midiA.begin(MIDI_CHANNEL_OMNI);
        midiF.begin(MIDI_CHANNEL_OMNI);
        midiA.turnThruOff();
        midiF.turnThruOff();
        if (midiA.read())  // If we have received a message
            midi::MidiType msgType = midiA.getType();
            byte channel = midiA.getChannel();
            byte data1 = midiA.getData1();
            byte data2 = midiA.getData2();
            //midiA.send(msgType, data1, data2, channel);     // <-- works
            midiF.send(msgType, data1, data2, channel);   // <-- does not work, locks up Teensy
    May 2018
    Portland, OR USA
    38
    Can someone try this code on their T3.6 to see if it locks up? No soldering required, because the no MIDI data ever comes out the port.
    Steve
    20,309
    I'm traveling without access to my workbench until Monday.
    When I do return, is there any chance you could give me a test program which only transmits on the problematic port, without waiting for input from another port? That way, I can just run it on a Teensy 3.6 and connect my oscilloscope to the transmitting pin, without needing to find MIDI gear that will send data to a different port than the one supposedly have the issue.
    I ask this only because my workbench has an oscilloscope that's always ready to use. But if I have to make serial MIDI, that's not normally on my workbench. I would need to set up another Teensy or go get a MIDI keyboard and wire stuff up. If you can give me a test program which simply transmits without needing input, I can test that much easier and quicker.
    5,052
    Actually this may not surprise me.
    On Teensy 3.6 the hardware for Serial6 has a complete different sub-system associated with it.
    That is Serial6 used LPUART0 (Chapter 62 of the PDF manual), whereas Serial1-5 use UARTS (chapter 59).
    But wonder what is crashing on it.... I don't know anything about MIDI, but maybe as Paul mentioned if you have a simple enough example that crashes without external inputs, would be possible to debug...
    5,052
    Note: I tried some simple test of it, like:
    #include <MIDI.h>
      while (!Serial && millis() < 5000) ;
      Serial.println("After Midi begins");
      Serial.println("After turn through off");
    uint16_t loop_count = 0;
      Serial.printf("Loop: Before first Send %d", ++loop_count);  Serial.flush();
      midiF.send(midi::NoteOn, 47, 42, 12);
      midiF.send(midi::NoteOn, 42, 47, 12);
      Serial.println("Loop: after second Send"); Serial.flush();
    But so far it is running fine, no hangs
    Those two messages come out of one of the examples... Don't know what they do...
    Maybe try something like, your first program, but add in maybe something like:
        Serial.printf("t:%d c:%x data1: %x data2:%x\n", millis(), channel, data1, data2); Serial.flush();
    And see if you get any set of messages printed out... Then maybe we can try simple program that just outputs those commands, with timing near what you recorded.
    May 2018
    Portland, OR USA
    38
    Thanks guys for looking into this. Really super appreciate it. When I get back to work Monday morning I will try the samples above.
    KurtE, Maybe some timing delays would help??? What exactly do you think your coach is doing differently that made it work?
    Paul, I will also try to write the smallest program I can to test this and come up with a fail result. I wonder if itís the midi code or the serial port code. Maybe just doing serial writes would cause the same problem.
    Thanks again,
    Steve
    May 2018
    Portland, OR USA
    38
    Hi Paul,
    Here's an example. Middle C on/off...
    #include <MIDI.h>
        // Serial hardware UART 6
        // MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, midiF);  <--- this works SERIAL #1
      midiF.sendNoteOn(60, 127, 1);
      midiF.sendNoteOff(60, 127, 1);
    May 2018
    Portland, OR USA
    38
    Maybe I have an issue with my T3.6... even this hangs. BTW changing 6 to 1-5 works (using the appropriate pins).
    I tried with no MIDI driver to remove complexity, just sending a serial byte 0xF8 = MIDI clock, so you can see it in MIDI-OX.
      Serial6.begin(31250);
      Serial6.write(0xF8);
    2,250
    Quote Originally Posted by SteveBar View Post
    Maybe you try with the classic
      while(millis()<1000);
    to slow down (hold) setup() for some time before calling Serial6.begin
    All others have this line, so I would try this
    May 2018
    Portland, OR USA
    38
    Hi Paul,
    We ordered and just received another couple T36's and did a test. Our original T36 has a bad Serial6, the new ones work fine. :-)
    I don't know how to change the name of this thread or delete it, which I think we should. That is a terrible name for a thread when it is not factual. :-(
    As admin please feel free to do what is needed.
    Thanks,
    Steve
    9,032
    Glad you got that resolved - even if finding you broke a Teensy
    I found I can change thread Title : Thread: T3.6 crash when using Serial Port #6 for MIDI - after Teensy Damaged
    May 2018
    Portland, OR USA
    38
    Thanks.
    I wonder how Serial6 got damaged??? I was soldering on the belly-pads to get TX6 cabled up... it may have arrived that way too???
    Steve
    9,032
    PJRC subjects every Teensy to a bed of nails test against every pin for some significant degree of testing so it wasn't open or dead at that point.
    Do pins 47 & 48 both have digital read and write function at this point? If connected together can one output to the other for input High and Low?
