Results 1 to 3 of 3
Thread: Enable pin
    Aug 2016
    149
    Enable pin
    I use the charger chip MC34673,in accordance with internal block diagram the pin ΕΝ it is not floating but it's connected with one pull-down resistor.
    https://imgur.com/a/Cyb8Dgd
    When there is internal pull-up or pull-down resistor to the ΕΝ pin it is necessary to connect and with a externall pull-up or pull-down resistor or directly connect the microcontroller pin to the EN pin??
    Apr 2019
    12
    You can connect it directly without any other resistor. Check it with a voltmeter if you want reassurance that it's pulling down to ground.
    Aug 2016
    149
    For example the TPS61291 (page 7) in the block diagram there is no internal pull-down resistor.
    In this case we should to put external resistor,correctly??
    Generally when it exists internal pull-down resistor we drive directly the EN pin by the microcontroller??
