Results 1 to 3 of 3
Thread: counting F8 without missing one
    Jun 2019
    2
    hello,
    i am going back to a project that i abandonned a few months ago, because it involved counting every incoming F8 (clock) from a MIDI stream ( coming out of an Electribe mkII ) in a very precise way, even at high BPM.
    the problem was that the sketch was too slow and the buffer must be filled with F8, so occasionnaly missing some and getting wrong tempo indications.
    now i am rewriting the sketch for teensy 3.5 and would like to get a better method for dealing with F8 messages
    i put the main structure of my program hereunder ;
    my questions are :
    - would it be better to use interrupts to count F8 ? using setHandleClock ?
    - i had chosen not to use the MIDI library, because i had trouble recognizing the NRPN messages from Electribe. does any of you have positive experience with properly recognizing NRPN messages with the library ?
    - generally speaking, any tip on dealing precisely with F8 messages ?
    #include <Arduino.h>
    #include <Encoder.h>
    #include <U8x8lib.h>
    #ifdef U8X8_HAVE_HW_SPI
    int compteurF8 ;
    long  moment, oldtimeF8, dureeF8 ;
    U8X8_SSD1306_128X64_NONAME_SW_I2C u8x8(/* clock=*/ 18, /* data=*/ 19, /* reset=*/ U8X8_PIN_NONE);   // OLEDs without Reset of the
        u8x8.begin();
        u8x8.setFont(u8x8_font_amstrad_cpc_extended_r);
        Serial1.begin(31250); // pour la lecture de Rx3 Tx3
        boolean keepAnalyzing ;
        if (Serial1.available() > 0)
            byte Buff = 0 ;
            Buff = Serial1.read();
            keepAnalyzing = true ;
            if ( Buff == 0xF8 )
                do
                    compteurF8++ ;
                    if ( compteurF8 >= 24 ) {
                        moment = millis();
                        dureeF8 = (moment - oldtimeF8 ) / 24 ;
                        oldtimeF8 = moment;
                        compteurF8 = 0;
                    if ( Serial1.available() )
                    { keepAnalyzing = false ; }
                } while ( Buff == 0xF8 && keepAnalyzing ) ;
            if ( keepAnalyzing )
                switch (Buff & B11110000)
                    case (0xB0):
                    case (0x90) :
                    break ;
                    case (0x80) :
                    default :
                    break ;
    1,134
    You've left out the important bits. What is the code doing when it gets Note on/off or Control Change? Post ALL the code.
    But why not handle the 0xF8 in the switch statement? You're handling a serial stream of data. Looking for 0xF8 first, doesn't speed things up if it has Control Change and/or Note On messages in front of it.
    Pete
    Jun 2019
    2
    i left the 0xF8 out of the switch in order to quickly eliminate them from the buffer ;
    as an Electribe sends 6 0xF8 by step, they are usually much more present in the stream than notes
