Page 2 of 2 FirstFirst 1 2
Results 26 to 35 of 35
Thread: Teensy 2.0 Code MIDI Box Help!!
  1. #26
    Jun 2019
    17
    Quote Originally Posted by oddson View Post
    const int A_PINS = 1; // number of Analog PINS
    Set the number of Analog pins to 1 and connect to A0 to test with one pot. Add each pot to A1, A2 etc. and increment the A_PINS with each added pot.
    Analogs are working i changed the code like you said i have connected 3 of them(2 Linear potentiometers and 1 rotary Potentiometer) so they worked fine just need to solder them better. But the buttons now don't i left 1 button in the code but it wasn't working.
    The code i only need help is for the buttons now.
    //************LIBRARIES USED**************
    // include the ResponsiveAnalogRead library for analog smoothing
    // include the Bounce library for 'de-bouncing' switches -- removing electrical chatter as contacts settle
    #include <Bounce.h>
    //usbMIDI.h library is added automatically when code is compiled as a MIDI device
    // ******CONSTANT VALUES********
    // customize code behaviour here!
    const int channel = 1; // MIDI channel
    const int A_PINS = 3; // number of Analog PINS
    const int D_PINS = 1; // number of Digital PINS
    const int ON_VELOCITY = 99; // note-one velocity sent from buttons (should be 65 to  127)
    // define the pins you want to use and the CC ID numbers on which to send them..
    const int ANALOG_PINS[A_PINS] = {A0,A1,A2};
    const int CCID[A_PINS] = {21,22,23};
    // define the pins and notes for digital events
    const int DIGITAL_PINS[D_PINS] = {0};
    const int note[D_PINS] = {60};
    const int BOUNCE_TIME = 7; // 5 ms is usually sufficient
    const boolean toggled = true;
    //******VARIABLES***********
    // a data array and a lagged copy to tell when MIDI changes are required
    byte data[A_PINS];
    byte dataLag[A_PINS]; // when lag and new are not the same then update MIDI CC value
    // not sure if there is a better way... some way run a setup loop on global array??
    // use comment tags to comment out unused portions of array definitions
    // initialize the ReponsiveAnalogRead objects
    ResponsiveAnalogRead analog[]{
      {ANALOG_PINS[0],true},
      {ANALOG_PINS[1],true},
      {ANALOG_PINS[2],true},
      //{ANALOG_PINS[3],true},
      //{ANALOG_PINS[4],true},
      //{ANALOG_PINS[5],true},
      //{ANALOG_PINS[6],true},
      //{ANALOG_PINS[7],true},
    // initialize the bounce objects
    Bounce digital[] =   {
      Bounce(DIGITAL_PINS[0], BOUNCE_TIME),
     // Bounce(DIGITAL_PINS[1], BOUNCE_TIME),
     // Bounce(DIGITAL_PINS[2], BOUNCE_TIME),
     // Bounce(DIGITAL_PINS[3], BOUNCE_TIME),
    // loop to configure input pins and internal pullup resisters for digital section
      for (int i=0;i<D_PINS;i++){
        pinMode(DIGITAL_PINS[i], INPUT_PULLUP);
      getAnalogData();
      getDigitalData();
      while (usbMIDI.read()) {
         // controllers must call .read() to keep the queue clear even if they are not responding to MIDI
    //************ANALOG SECTION**************
    void getAnalogData(){
      for (int i=0;i<A_PINS;i++){
        // update the ResponsiveAnalogRead object every loop
        analog[i].update();
        // if the repsonsive value has change, print out 'changed'
        if(analog[i].hasChanged()) {
          data[i] = analog[i].getValue()>>3;
          if (data[i] != dataLag[i]){
            dataLag[i] = data[i];
            usbMIDI.sendControlChange(CCID[i], data[i], channel);
    void getDigitalData(){
      digital[i].update();
        if (digital[i].fallingEdge()) {
         usbMIDI.sendControlChange(note[i], ON_VELOCITY, channel);
       // Note Off messages when each button is released
        if (digital[i].risingEdge()) {
          usbMIDI.sendControlChange(note[i], 0, channel);
    And one more silly question what should the buttons be connected with the (Signal(pin that goes on Teensy) and Power(VCC)) or (Signal(pin that goes on Teensy) and GrounD(GND))??
  2. #27
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,117
    Buttons can be active even if not connected as they work by pulling the signal low while an internal pullup resistor, activated in the setup, otherwise keeps the signal high; even if nothing is connected
    https://www.pjrc.com/teensy/td_digital.html
    A momentary switch pulls the signal to ground and the bounce library sends a fallingEdge event when the chatter stops and the signal is at ground.
    https://www.pjrc.com/teensy/td_libs_Bounce.html
  3. #28
    Feb 2013
    1,117
    My bad. For incrementally adding analog, you can just change the value here to an explicit:
    Just replace A_PINS with 1 to 8.
  4. #29
    Jun 2019
    17
    Amm all the Analogs are working fine (all 4 rotary potentiometers and 4 slide potentiometers)
    I only need the buttons to function properly now. So i don't really understand with this code why should i change A_PINS
  5. #30
    Feb 2013
    1,117
    You dont.... button part is in previous post.
    Connect digital pins to ground via momentary switches..
  6. #31
    Jun 2019
    17
    SO the code is OK i just need to connect the buttons with ground, power and signal. For now i have like this on Buttons Red=power and blue= Signal. So i need to attach the ground cable to the buttons?
ID:	16793Click image for larger version.
  7. #32
    Feb 2013
    1,117
    Switches do not have power connected.
    They are connected to ground on one side and the data pin on the other.
    If your red wire is ground and the blue wires go to pins 0 to 3 then that should work.
  8. #33
    Jun 2019
    17
    In my case from that picture the RED wire is power(VCC) and BLUE wires for pins 0-3. BLACK wire is for ground(GND).
    So then in my case i need to switch the RED(VCC) and BLACK(GND) wire so that in the end it should be BLUE for pins 0-3 on one side and BLACK(GND) on the other side for the switches(buttons) .???
    But what if i only add a 10k ohm resistor to the RED(VCC) wire should that fixed it??
  9. #34
    Jun 2019
    17
    My final project is done and it is functioning properly. I just want to say thank you to everybody that helped me and especially thank you oddson for you help and time for helping me to complete this project in the right time.
  10. #35
    20,171
    Glad you got it all working in the end.
    Any advise to share, for beginners seeking to build a similar MIDI controller who might later find this thread by search?
