Results 1 to 4 of 4
Thread: assembly language with teensyduino
    Is it possible to include assmbly language in teensyduino projects?
    Finland
    120
    Of course. The easiest way is to write inline assembly.
    Feb 2014
    Colmar, France
    2,459
    Naturally. Not only in Teensyduino but in all embedded developments which rely on the gcc compiler because it supports inline assembly. Parts of the Teensyduino audio library are written in assembly. The file dspinst.h declares for example the inline function wrappers for the most common ARM DSP assembly functions and can serve as a tutorial.
    More details about gcc and inline assembly here: http://www.ethernut.de/en/documents/arm-inline-asm.html
    Thanks,
    I will have a look into dspinst.h and the audio lib.
