Page 2 of 2 FirstFirst 1 2
Results 26 to 28 of 28
Thread: string ensemble chorus - anyone try it?
  1. #26
    If I don't offset the output indexes with the LFO, it's silent. If I allow it to add the offsets but keep them static, it's silent. Hmm... maybe the noise comes from discontinuous jumps in the LFO table? Sometimes it does offset by 2 or 3. I'll double the resolution of the LFO table and double the wavetable index increment rate.
    Update: nope, doubling the resolution of the wavetable made no difference.
    Just throwing the buffer data right back with the input index doesn't cause the artifact noise. Sigh.
  2. #27
    1,155
    I've just got your code partially working on a Teensy 3.2
    That noise is definitely caused by the lfo table. I'll have a closer look at it tomorrow.
    Pete
  3. #28
    DOH! I figured it out!
    I was not accounting for the LFO wrapping the buffer index BACKWARDS! I have corrected that, and now it works!
    I'll be doing further commits as I tweak the LFO waveform. I suppose on a Teensy 3.5 or 3.6 you can just import the math library and do it on the fly.
    I will be buying a Teensy 3.6 and one of these today: http://www.tindie.com/products/Black...ac_prod_search
