I want to build a microphone with the Teensy 3.2., Audio Shield and MAX4466 microphone. I connected the mic to the line-in input and loaded the following code on the teensy:
// Record sound as raw data to a SD card, and play it back.
// Requires the audio shield:
//   http://www.pjrc.com/store/teensy3_audio.html
// Three pushbuttons need to be connected:
//   Record Button: pin 0 to GND
//   Stop Button:   pin 1 to GND
//   Play Button:   pin 2 to GND
#include <Bounce.h>
AudioInputI2S            i2s2;           //xy=105,63
AudioAnalyzePeak         peak1;          //xy=278,108
AudioRecordQueue         queue1;         //xy=281,63
AudioPlaySdRaw           playRaw1;       //xy=302,157
AudioOutputI2S           i2s1;           //xy=470,120
AudioConnection          patchCord1(i2s2, 0, queue1, 0);
AudioConnection          patchCord2(i2s2, 0, peak1, 0);
AudioConnection          patchCord3(playRaw1, 0, i2s1, 0);
AudioConnection          patchCord4(playRaw1, 0, i2s1, 1);
AudioControlSGTL5000     sgtl5000_1;     //xy=265,212
// For a stereo recording version, see this forum thread:
// https://forum.pjrc.com/threads/46150?p=158388&viewfull=1#post158388
// A much more advanced sound recording and data logging project:
// https://github.com/WMXZ-EU/microSoundRecorder
// https://github.com/WMXZ-EU/microSoundRecorder/wiki/Hardware-setup
// https://forum.pjrc.com/threads/52175?p=185386&viewfull=1#post185386
// Bounce objects to easily and reliably read the buttons
Bounce buttonRecord = Bounce(0, 8);
Bounce buttonStop =   Bounce(1, 8);  // 8 = 8 ms debounce time
Bounce buttonPlay =   Bounce(2, 8);
// which input on the audio shield will be used?
#define SDCARD_CS_PIN    10
#define SDCARD_MOSI_PIN  7
#define SDCARD_SCK_PIN   14
//#define SDCARD_CS_PIN    BUILTIN_SDCARD
//#define SDCARD_MOSI_PIN  11  // not actually used
//#define SDCARD_SCK_PIN   13  // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN    4
// Remember which mode we're doing
int mode = 0;  // 0=stopped, 1=recording, 2=playing
// The file where data is recorded
File frec;
  // Configure the pushbutton pins
  pinMode(0, INPUT_PULLUP);
  pinMode(1, INPUT_PULLUP);
  pinMode(2, INPUT_PULLUP);
  AudioMemory(60);
  sgtl5000_1.enable();
  sgtl5000_1.volume(0.5);
  // Initialize the SD card
  SPI.setMOSI(SDCARD_MOSI_PIN);
  SPI.setSCK(SDCARD_SCK_PIN);
    while (1) {
  // First, read the buttons
  buttonRecord.update();
  buttonStop.update();
  buttonPlay.update();
  // Respond to button presses
  if (buttonRecord.fallingEdge()) {
    Serial.println("Record Button Press");
    if (mode == 2) stopPlaying();
    if (mode == 0) startRecording();
  if (buttonStop.fallingEdge()) {
    Serial.println("Stop Button Press");
    if (mode == 1) stopRecording();
  if (buttonPlay.fallingEdge()) {
    Serial.println("Play Button Press");
    if (mode == 0) startPlaying();
  // If we're playing or recording, carry on...
  if (mode == 1) {
    continueRecording();
  if (mode == 2) {
    continuePlaying();
  // when using a microphone, continuously adjust gain
  if (myInput == AUDIO_INPUT_MIC) adjustMicLevel();
void startRecording() {
  Serial.println("startRecording");
  if (SD.exists("RECORD.RAW")) {
    // The SD library writes new data to the end of the
    // file, so to start a new recording, the old file
    // must be deleted before new data is written.
    SD.remove("RECORD.RAW");
  frec = SD.open("RECORD.RAW", FILE_WRITE);
  if (frec) {
    queue1.begin();
    mode = 1;
void continueRecording() {
  if (queue1.available() >= 2) {
    byte buffer[512];
    // into a 512 byte buffer.  The Arduino SD library
    // writes are used.
    memcpy(buffer, queue1.readBuffer(), 256);
    queue1.freeBuffer();
    memcpy(buffer+256, queue1.readBuffer(), 256);
    // write all 512 bytes to the SD card
    elapsedMicros usec = 0;
    frec.write(buffer, 512);
    // Uncomment these lines to see how long SD writes
    // are taking.  A pair of audio blocks arrives every
    // 5802 microseconds, so hopefully most of the writes
    // take well under 5802 us.  Some will take more, as
    // the SD library also must write to the FAT tables
    // and the SD card controller manages media erase and
    // wear leveling.  The queue1 object can buffer
    // approximately 301700 us of audio, to allow time
    // for occasional high SD card latency, as long as
    // the average write time is under 5802 us.
    //Serial.print("SD write, us=");
    //Serial.println(usec);
void stopRecording() {
  Serial.println("stopRecording");
  queue1.end();
  if (mode == 1) {
      frec.write((byte*)queue1.readBuffer(), 256);
    frec.close();
  mode = 0;
void startPlaying() {
  Serial.println("startPlaying");
  playRaw1.play("RECORD.RAW");
  mode = 2;
void continuePlaying() {
  if (!playRaw1.isPlaying()) {
    playRaw1.stop();
    mode = 0;
void stopPlaying() {
  Serial.println("stopPlaying");
  if (mode == 2) playRaw1.stop();
  mode = 0;
void adjustMicLevel() {
  // TODO: read the peak1 object and adjust sgtl5000_1.micGain()
  // if anyone gets this working, please submit a github pull request :-)
Since yesterday, the recordings are saved at an increased speed. It's like a fast-forward recording.
I have already tried to find a solution but unfortunately unsuccessful. I hope someone here can help me.
