Results 1 to 4 of 4
Thread: Teensy LC pin 10 digital Read
    Apr 2015
    12
    I'm having an issue with my Teensy LC. I'm using it for a Rotary Encoder. All the other pins i am using are working fine and i'm getting 0 and 1 values as i turn it. For pin 10 it's only printing 0. Any info on why it might not be reading properly?
    thanks!
    2,086
    please provide the sketch you are running and maybe a photo of your setup and which encoder are you using? (vendor/model) Do you have soldered headers?
    20,312
    Quote Originally Posted by lordscruffo View Post
    Very likely a mistake was made somewhere. Maybe a physical wiring problem? Maybe on the software side? Nobody can even begin to guess when you don't show us the code and hardware (photos) you're actually using.
    9,037
    I saw that with an encoder recently - when I plugged on the wires I was shifted by one so only one pin was changing on rotation and it resulted in a 0 & 1 toggle in the displayed data. Check your wiring to be good with proper and pin association.
    If it isn't that - then code and a picture might show the issue.
