Results 1 to 3 of 3
Thread: FlightSimControls proper detection of connect/disconnect to XpLane
    I am doing my first attempts to use FlightSimControls.
    At first , I was using a single FlightSim.update() at the beginning of loop().
    Worked so far in case XPlane is already running.
    But the typical situation is, that my Teensy Board is already running for a while until XPlane comes up and the communication may start.
    As the the next attempt, I tried this code which does not work:
      bool FSactive=false;
      FlightSim.update();
      delay(400);
      Serial.println("After initial FlightSim.update()");
      while(1)
        if ((FlightSim.isEnabled()==true) && (FSactive==false))
          Serial.println("Xplaen is ONLINE now");
          FSactive=true;
          FlightSim.update();
          updateGearLEDs();
        if((FlightSim.isEnabled()==false) && (FSactive==true))
          FSactive=false;
          Serial.println("XPlane now OFFLINE");
        if((FlightSim.isEnabled()==false) && (FSactive==false))
          FSactive=false;
       } //while
    Is there a reliable method to detect whether XPlane is running or not and/or initiate a reconnect in case the connection is lost?
    Mar 2020
    Southampton UK
    7
    Hi, did you resolve this and if so could you post the solution, thanks Bob
    No real progress. It works with some problems-
