FlightSimControls proper detection of connect/disconnect to XpLane
drnicolas
I am doing my first attempts to use FlightSimControls.
At first , I was using a single FlightSim.update() at the beginning of loop().
Worked so far in case XPlane is already running.
But the typical situation is, that my Teensy Board is already running for a while until XPlane comes up and the communication may start.
As the the next attempt, I tried this code which does not work:
  bool FSactive=false;
  FlightSim.update();
  delay(400);
  Serial.println("After initial FlightSim.update()");
  while(1)
    if ((FlightSim.isEnabled()==true) && (FSactive==false))
      Serial.println("Xplaen is ONLINE now");
      FSactive=true;
      FlightSim.update();
      updateGearLEDs();
    if((FlightSim.isEnabled()==false) && (FSactive==true))
      FSactive=false;
      Serial.println("XPlane now OFFLINE");
    if((FlightSim.isEnabled()==false) && (FSactive==false))
      FSactive=false;
   } //while
Is there a reliable method to detect whether XPlane is running or not and/or initiate a reconnect in case the connection is lost?
