Hi All,
Yes - another custom Teensy troubleshooting thread!
I've built my own but can't get it to work. Before getting into too much detail, can I just check a few things?
Here's what I've found so far.
Power appears clean at all power pins - checked with an oscilloscope.
If I monitor the Reset line, I can see it pulsing (like here: http://www.appfruits.com/2015/03/building-your-own-custom-teensy/ )
If I ground the Prog line, reset is also pulled to ground
However, if I monitor the clock and data lines from the MKL04, I can't see anything happening. No clock or data pulses.
Do I have a faulty/blank MKL04? I can try another one, but reluctant to pull it off my board.
Thanks!
Andrew
Thanks!
Andrew
