Teensy Audio Example Sketches Won't Compile on Teensy LC
ramgarden
New member
I bought the Teensy LC and the Prop Shield LC and soldered them together.
I tried to compile the example audio sketches and none of them will compile.
The most basic one that includes the binary files for the sounds should be the easiest one to work, right?
Or is there a different example code I should try with the Prop Shield LC that's actually made for the LC version :confused:?
File->Examples->(Examples for Teensy LC)Audio->SamplePlayer
Hitting Verify button gives these errors:
Arduino: 1.8.9 (Windows 10), TD: 1.46, Board: "Teensy LC, Serial, 48 MHz, Smallest Code, US English"
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_fft1024.cpp:34:13: warning: 'void copy_to_fft_buffer(void*, const void*)' defined but not used [-Wunused-function]
static void copy_to_fft_buffer(void *destination, const void *source)
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_fft1024.cpp:44:13: warning: 'void apply_window_to_fft_buffer(void*, const void*)' defined but not used [-Wunused-function]
static void apply_window_to_fft_buffer(void *buffer, const void *window)
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_midside.cpp: In member function 'virtual void AudioEffectMidSide::update()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_midside.cpp:34:12: warning: unused variable 'pa' [-Wunused-variable]
uint32_t *pa, *pb, *end;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_midside.cpp:34:17: warning: unused variable 'pb' [-Wunused-variable]
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_midside.cpp:34:22: warning: unused variable 'end' [-Wunused-variable]
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_midside.cpp:35:11: warning: unused variable 'a12' [-Wunused-variable]
uint32_t a12, a34; //, a56, a78;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_midside.cpp:35:16: warning: unused variable 'a34' [-Wunused-variable]
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_midside.cpp:36:11: warning: unused variable 'b12' [-Wunused-variable]
uint32_t b12, b34; //, b56, b78;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_midside.cpp:36:16: warning: unused variable 'b34' [-Wunused-variable]
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_adc.cpp: In static member function 'static void AudioInputAnalog::isr()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_adc.cpp:119:2: warning: 'daddr' is used uninitialized in this function [-Wuninitialized]
if (daddr < (uint32_t)analog_rx_buffer + sizeof(analog_rx_buffer) / 2) {
C:\Users\Brenna\AppData\Local\Temp\ccEFea6d.s: Assembler messages:
C:\Users\Brenna\AppData\Local\Temp\ccEFea6d.s:291: Error: selected processor does not support `smull r0,ip,r3,r5' in Thumb mode
C:\Users\Brenna\AppData\Local\Temp\ccEFea6d.s:292: Error: shifts in CMP/MOV instructions are only supported in unified syntax -- `mov ip,ip,asl r6'
C:\Users\Brenna\AppData\Local\Temp\ccEFea6d.s:293: Error: unshifted register required -- `orr r0,ip,r0,lsr r7'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_pt8211.cpp: In static member function 'static void AudioOutputPT8211::isr()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_pt8211.cpp:107:25: error: 'class DMAChannel' has no member named 'TCD'
saddr = (uint32_t)(dma.TCD->SADDR);
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s.cpp: In static member function 'static void AudioInputI2S::isr()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s.cpp:110:2: warning: 'daddr' is used uninitialized in this function [-Wuninitialized]
if (daddr < (uint32_t)i2s_rx_buffer + sizeof(i2s_rx_buffer) / 2) {
Error compiling for board Teensy LC.
Teensy Audio Library
Supported Hardware:
Audio Adaptor, for 16 bit stereo input and output.
Dual Audio Adaptors for 16 bit quad channel input and output.
S/PDIF optical digital audio output, for 16 bit stereo sound.
Teensy 3.6, Teensy 3.5, Teensy 3.2 & 3.1 built-in DAC, for 12 bit mono output.
Teensy 3.6 and Teensy 3.5 built-in DACs, for 12 bit stereo output.
Teensy 3.6, Teensy 3.5, Teensy 3.2 & 3.1 & 3.0 ADC, for 13 bit mono input.
Teensy 3.6, Teensy 3.5, Teensy 3.2 & 3.1 ADCs, for 13 bit stereo input.
Teensy 3.6, Teensy 3.5, Teensy 3.2 & 3.1 & 3.0 PWM, for approx 9-10 bit mono output.
USB Audio, for bi-directional stereo streaming to/from a PC.
I thought I could load a WAV file onto the 8MB storage on the prop shield and make it play through a speaker. Does it really need all this workaround and jumpers and things?
But yes, you can. It's not about "workaround and jumpers", it's about engineering, which means processing and outputting a signal on the Teensy LC and feeding it into the appropriate pins of the prop shield. Since the prop shield is intended to interoperate with a whole bunch of different Teensy models, a minimum of wiring is naturally required to adapt everything to your specific setup.
