Syncing midi clock across several outputs
massahwahl
I have been working on putting together a fairly elaborate midi controller that has 5 hardwareSerial midi outputs going to various Korg volca synths but I am having a difficult time implementing a way to sync then at all together.
With the sendRealTime(clock) function, do I need to setup a running clock and send that function at the correct interval? Or do I need to send it as part of my actual function that will send my notes and sequences out? I can't seem to find a good breakdown of what the best practices or procedures are for this part of the process so any guidance is appreciated!
You'd need to setup a running clock using a timer. This essentially runs independent of the other functions and sends out clock pulses to all serial port simultaneously.
I have setup a timer using millis but I guess where I have gotten lost is with how to update all of the outputs at the same time? I have not been able to figure out the correct syntax to even send the clock function:
MIDI1.sendRealTime(clock)
Doesn’t work and I’ve tried a few variations of it as well and can’t get it to accept it.
I'm not sure on the exact syntax as I only receive clock in my application. Assuming that you declared a serial midi as shown here: MIDI library and looking at the USBMidi syntax shouldn't it be MIDI1.sendRealTime(MIDI1.clock) ?
I believe CLOCK is upper case.
Edit.... not sure if it us in MIDI? I see examples on Ardunio forum with lowercase.
Edit 2... on my tablet so I can't check, but the library defs seem to say it's title case: "Clock"
Have you confirmed other MIDI is working?
I did finally get it to work but it took some serious google-fu to finally find a good example that did it:
MIDI1.sendRealTime(midi::Clock);
I was able to sync all 5 of my outputs by butchering someone else’s example by it’s pretty gross looking, I have not been able to tear it down yet to only what I need:
void newTempo(int offset)
    tempo += offset;
    if (tempo < TEMPO_MIN)
        tempo = TEMPO_MIN;
    else if (tempo > TEMPO_MAX)
        tempo = TEMPO_MAX;
    Timer1.setPeriod(calcTempoMicros());
void clockTick()
    MIDI2.sendRealTime(midi::Clock);
    MIDI3.sendRealTime(midi::Clock);
    MIDI4.sendRealTime(midi::Clock);
    MIDI5.sendRealTime(midi::Clock);
    currentTick++;
    if (currentTick == 24)
        currentTick = 0;
I would like to get that cleaned up at some point but it does at least work to allow my rotary encoder to change the bpm
