Results 1 to 3 of 3
Thread: Connect two Teensy via MIDI USB HOST to Teensy MIDI USB 16x16
    Jun 2019
    14
    I want to build a box that provides midi routing and a usb midi interface
    - connects to a PC by USB and provides 16x16 USB midi to the PC.
    - provides 12 x 12 midi serial ports
    - has a display and pushbuttons for selecting which input is routed to which output.
    Since each Teeensy3.6 has 6 usarts, so I figure I could use 2 teensy connected by USB-HOST to USB. One of the teensy is connected by USB to the PC, provding a 16x16 virtual cables. The second teensy is also running a MIDI USB 16x16 and is connected to the first teensy USB host.
    My question is if the USB-HOST midi driver would work if a teensy USB MIDI 16x16 is connected? Does the MIDI USB HOST support the 16x16 virtual cables?
    22,649
    Quote Originally Posted by widdly View Post
    Yes, USBHost_t36 supports virtual cables.
    Jun 2019
    14
    Great, thanks Paul
